Just Bought a VF 570 E46 M3 – Looking for Baseline & Reliability Advice
    Hey everyone,
    After being away from BMWs for quite a while, I’m finally back and just put a deposit down on this car. Super excited to be back in an E46 M3, especially one running a VF 570 supercharger setup.
    Once I take delivery, I plan on doing all the usual baseline maintenance right away (oil change, brakes, fluids, etc.), but I wanted to tap into the community here to make sure I’m not missing anything important—especially given the forced induction.
    A few questions I have so far:
    1. Oil choice:
      Since the car is running a VF 570, should I be sticking with 10W-60, or are some of you running a different weight with good results? Any brand preferences for boosted S54s?
    2. Oil change intervals:
      How often are you guys changing oil on a supercharged setup—3k miles, sooner?
    3. Spark plugs:
      What plugs and heat range are you running with the VF 570? How often do you inspect or replace them?
    4. Supercharger maintenance:
      Is there any routine maintenance I should be doing on the VF unit itself (oil, couplers, belts, etc.) that’s commonly overlooked?
    5. Fueling & tune:
      Anything specific I should verify regarding injectors, fuel pump, or tune version? Is there a recommended way to confirm everything is healthy/logging properly?
    6. Reliability items:
      Outside of the obvious (rod bearings, VANOS, subframe), are there any boost-specific weak points I should address early on?
    7. Cooling:
      Any cooling upgrades that are considered “must-haves” for a VF car, especially for spirited driving or warmer climates?
    The car seems well cared for, but I want to start ownership on the right foot and make sure everything is solid before pushing it. Any advice, lessons learned, or “do this before you regret it” tips would be greatly appreciated.
    Thanks in advance—looking forward to being back in the community!
    I ran one of the 570 kits for years…super reliable, never had an issue, but I'd suggest getting a tune as the VF tune is quite crap IMO. oil is easy to change on the blower, overall very solid setup that makes good power for the street
      Make sure you've bookmarked this thread too: https://nam3forum.com/forums/forum/m...t-parts-thread
        Did it, I was just looking to see if there is anything else anyone could mention.
          Does anyone know what would be the best spark plugs to use? Also want to switch to RedLine 10W60 oil should I make the switch?
            I had this same questions and my tuner just told me to go with the copper plugs 1 stage colder. They require more frequent changes but cheaper overall.
              It's like $3-4 more I don't know how does that make sense to them?
                I maintain it just as if it were stock with the addition of checking the charge cooler's fluid level, periodically checking the charge cooler pump runs (set car to accessory power and you should hear it running), and changing the vortech blowers oil every OCI with royal purple atf. Other than that just use the correct parts from that maintenance thread mentioned and you're set.
                  Thank you!!!
