Turbo builds
  • Nicholas1996
    Originally posted by Mspir3d View Post
    Are you running a boost a pump?
    No sir. But the duty cycle is %95 . I may dump another 525 lph in the tank ( I have a Dual hanger) and see what it does. At this point I’m not sure if there is going back. I’m thinking of getting as much fuel as I can into it and seeing what the 6266 does when really cranked to the max. It’s got a 1.0 AR housing so it should flow well enough.
  • Mspir3d
    Originally posted by Nicholas1996 View Post
    Excited to see what yours puts down. Was going to to go do some road tuning on mine tonight but the weather looks bad.
    Edit: went out and did some tuning. Set up boost by gear. Ran out of fuel at 24ish psi on my 1100cc injectors. Car is fun for sure
  • Nicholas1996
    That's really good. Have you got on a dyno with it yet? You must be running some sticky tires. My firehawks grip well at 9-10 psi, but into the 20 psi range it will spin them above 90mph.
    Just some Kumho ecsta ps91. Nothing crazy. Once they’re warm they do Ok
  • Mspir3d
  • Nicholas1996
    Very nice, I just finished building my engine as well. I took it out for it's first 5 miles late last night. The last 7 months was a ton of work so I'm excited to get it broken in.
  • Mspir3d
    Originally posted by mleveroni View Post
    So I went with the rebuild which is where I am currently at.
  • mleveroni
    That's a really interesting setup. What's the story behind it?
    I picked up the infinity, maximum psi kit, and some of the fuel stuff off someone returning to stock. Just missing a turbo and some fuel lines. After it was running, added the flex fuel sensor, boost controller, and injectors. Ran like that for a little then I found an alarming amount of metal in the oil. Just assumed a bearing went bad so I took the motor out and tore it apart. To my surprise, everything looks fine, never found the source of the metal. Figured my options were to try my luck with another stock motor, or rebuild mine. So I went with the rebuild which is where I am currently at.
  • Mspir3d
    Interested in feedback from anyone running a 6870 or 6766. Especially in terms of spool time compared to a 6266. Was thinking about stepping up the turbo eventually from a 6266 JB to maybe a 6766 BB and wanted to know how much it would change when boost came in. Originally went with the 6266jb for a few reasons. First being that the motor was stock and I didn't think anything more was necessary. Second, the clutch was stock so I figured a journal bearing would spool a bit later and be easier on the clutch. Third, it was pretty cheap for a new one. However, now the motor is currently being built and I got a twin disk clutch.
    Here is my setup by the way:
    Maximum PSI kit (intake manifold, intercooler, spa exhaust, etc)
    Precision 6266JB
    Tial WG
    AEM Infinity
    AEM boost controller
    Flexfuel
    Dual In-tank walbro 450's
    8AN feed, 6AN return
    Radium Rail
    ID1050's
    30 shot of nitrous (never actually used and probably wont. Had it and just threw it in to be ridiculous)
    Motor (in the works, machined, new bearings, etc. Here are the highlights)
    -CP 9.5:1 pistons (87.25mm)
    -Carillo rods
    -ARP L19 headstuds
    -Supertech valve springs
    DKM twin disk clutch
    I didn't know things like pistons took 5 weeks, plus things are just out of stock from covid, so the motor is currently waiting at the machine shop. Once they have everything it should be quick, so I am hoping to have the car running by the end of August. I am happy with the 6266 and will run that for a bit, but with all this cash into the motor, I feel like it would be a waste not at least have a tune that steps it up a bit lol. It is worth noting that I have a map for E85 but mostly run pump 93. I can step up the boost on the new motor but on pump gas I wouldn't go crazy. So I am also wondering if the amount of boost it would take a 6766 to match the power of a 6266 at say 20psi would be significantly less or just negligible.
    Eventually I am going to change the turbo to a ball bearing, but my question is if there is much of a benefit to a 6766BB or 6870 over the 6266BB or 6466BB which most people use.
    On a side note, on stock motor on pump 93, I was running 12psi at most. The car had a base map that ran fine but was really just meant to be safe for the time being. Might have gone to maybe 14psi if everything looked good but never did. With this motor being lower compression, how much can I raise the boost and still be safe on pump gas?
  • Nicholas1996
    The precision was the same A/R
    Interesting. Mines a 1.0
  • Mspir3d
    Do you remember what at the precision was.? Mines a 1.0
  • Nicholas1996
  • Mspir3d
    What AR you running?
    The BW is a 64.5/67 with a .81 a/r
    I havent had experience with Garrett in over 15 years but I believe their reliability is similar to BW.
  • Nicholas1996
    Never really dealt with them. But Garrett’s make a lot of good oem turbo.
  • mleveroni
    What are the thoughts on a Garret GTX3584RS or a GTX3582R?
  • Nicholas1996
    I want to give bw a try. Your graph doesn’t look bad at all. Maybe give the BB turbos they offer a try and see what they do. My precision is starting to leak oil too. Garbage turbo.
