Everyone has their own opinion how to do it. I put the cheapest Walmart 10w40 I could find in it. It was changed at 50 and 500 miles. I’ll go back to the twin power 10w60 I get from fcpeuro in the next few days.
Turbo builds
Originally posted by Mspir3d View PostIt’s been a long time but I don’t think you can go wrong with a pilot hole to start with.
Maximum PSI install guide just says to coat the thread with "pipe dope" not sure what that is. What did you use?
Could I use jb weld on the threads and then thread the fitting and let it cure?
What did you use?
Finally got it done. Need to decide on a sealant though.
What did you use?
Originally posted by Dtmpowerjc View Post
It’s a thing, the stuff plumbers use.
The new axles arrived just barely in time for the last roll race of the season. It made for a good time and the car ran strong. A guy I know sold his GTR and picked up a beautiful c6 Z06. He took a little convincing because he’s raced me in the past but was kind enough to give me a good baseline run to start the day.
Originally posted by Mspir3d View PostThe new axles arrived just barely in time for the last roll race of the season. It made for a good time and the car ran strong. A guy I know sold his GTR and picked up a beautiful c6 Z06. He took a little convincing because he’s raced me in the past but was kind enough to give me a good baseline run to start the day.
I ordered a set of these:
https://www.seemslegitgarage.com/pro...d-stub-upgrade
They are great axles but maybe a warning would have been nice. The bolts on the cv joint by the wheel don't clear the upper control arm when the suspension is loaded. I contacted the company and it's normal and they need to "self clearance" 😂. So after some terrible noises especially going over bumps, they have cut a groove into my upper control arms and are no longer making noise...They appear to be very strong axles though. Other than the clearance problem, I have no complaints.
exciting. But bimmerworld took care of it thankfully!Last edited by Nicholas1996; 10-06-2020, 11:48 AM.
Originally posted by Mspir3d View PostMine has been in there for 5 years now and hasn't had a problem. The pipe dope has worked well for me.
curious about your spark plug setup, i have a set of NGK DCPR9EKP plugs and was curious what gap you used with your plugs, did you also use 9 series plugs?Last edited by nextelbuddy; 10-07-2020, 01:12 PM.
The box I have says dcpr9e. I think the plugs that are in now are gapped at .020 and the plugs going in I gapped down to .018. I tend to go through a decent amount of plugs but they’re super cheap at advance auto parts with the 15% off. If you’re not running a lot of pressure, a larger gap is better.Last edited by Mspir3d; 10-07-2020, 05:22 PM.
Originally posted by Mspir3d View PostThe box I have says dcpr9e. I think the plugs that are in now are gapped at .020 and the plugs going in I gapped down to .018. I tend to go through a decent amount of plugs but they’re super cheap at advance auto parts with the 15% off. If you’re not running a lot of pressure, a larger gap is better.
Originally posted by Nicholas1996 View Post
Jesus. Haha I’ll definitely look into them. I can only imagine mine are screaming and about to snap. Had a mishap with the car on Sunday. Bimmerworld Vanos line started leaking after 2k miles. Not exactly
