GB: Supersprint Exhaust Systems Part 2 by MpowerMotorsports
This topic is closed.
    Originally posted by gixxer View Post
    What's the SS part # for the v2 stepped?
    Neverminded, it's 044901, so the SS v2 stepped is 60mm with as stated, 2-bot flange.
      I'm pretty sure it's the same as all standard style headers which are 55mm outlets (2.16") The 60mm (2.36") reference is, I believe, the OD of the SS sect 1 that slips over as well as other aftermarket brands. The stock sect 1 starts out at like 58mm I think and increases slightly to 60mm at the sect 2 joint.
      I took my measurements back in like 2016/2017 so memory might be fuzzy, but when you see 60mm that's an aftermarket product meant as replacement for the stock pipes and 63.5mm is Supersprint "oversized."
      I know what I've written is pedantic, but the point is, if you're comparing flow, 63.5mm to 60mm is different than 63.5mm to 55mm.
      The slip fit end of the oversized sect 1 (v1 stepped) is actually 66.5mm to go over the 63.5 ends of the v1 stepped headers. It all adds up.
        I will know tomorrow.
        Any update on this? The new price list just makes this even more enticing.
          Not yet Abdul will ask tonight and we'll have an answer tomorrow (hopefully).
            Didn't plan on getting an exhaust yet but thanks for setting the GB up, I'm not going to pass this up.
            I have 1 question though. I like the 63.5 stepped header into the 63.5 catted sec1. Section 2 twin pipe shows it's 63.5 also, will this bolt up to the stock muffler or a muffler of my choice?
            Thanks
              Thanks
              Yes! Supersprint designed it to fit any rear section that used the OEM mounting points / pipe routing.
                The 63.5mm headers are really only compatible with Supersprint's Section 1. You have 3 options - from expensive to affordable: HJS catted, Resonated Catless, Catless.
                Ok, that was my question. The 63.5mm headers are only compatible with the new 63.5mm section 1, the SuperSprint HJS cats I currently have on the vehicle are apparently 60mm?
                So it sounds like the V2 stepped headers aren't on the table with this offering and I'd need to order both the headers and a new section 1, as well as a new section 2 to see the benefit of the 63.5mm.
                thanks
                  Are the prices for the catted sport and race kits backward? Catless race kit costs more than catless sport kit, but catted sport kit costs more than catted race kit. And individually the sport muffler is cheaper than the race muffler. Am I missing something or is it not adding up?
                    good catch.
                      thanks
                      Section 2 isn't exactly needed. It is if you are complete FBO (CSL airbox, cams, exhausts) as Obioban pointed out in his development of this section 2 with Supersprint.
                      The race rear section is more expensive than the sport on the catless kits.
                      The catted sport kit is indeed missing the 5% package discount, good catch. I can apply the discount after the order as I can't modify the live listing,
                        Double-checking before I pull the trigger - the 63.5 mm hjs catted sec 1 will bolt up to the stock sec 2?
                          Yes.
                            Wow this a great GB, considering either full sport catted system or just the cats and headers and section 2. Is there a performance detriment to not running the SS muffler, but running the rest of the pipes upstream of the muffler?
                              Versus the OEM? It will have slightly more volume, but it's reported the 63.5mm resonated twin-tube section 2 from Supersprint helps eliminate rasp.
                              excellent, thats just what im looking for. my main concern is stepping up and down diameters for exhaust piping.
                                Would it be possible to add the standard catted section 1 and/or the unresonated twin section 2 to the GB? I don’t have V1 headers on my car.
                                997.1 GT3 Carrara White/Black
                                C43 AMG Diamond Silver/Red​
