Originally posted by gixxer
GB: Supersprint Exhaust Systems Part 2 by MpowerMotorsports
This topic is closed.
I'm pretty sure it's the same as all standard style headers which are 55mm outlets (2.16") The 60mm (2.36") reference is, I believe, the OD of the SS sect 1 that slips over as well as other aftermarket brands. The stock sect 1 starts out at like 58mm I think and increases slightly to 60mm at the sect 2 joint.
I took my measurements back in like 2016/2017 so memory might be fuzzy, but when you see 60mm that's an aftermarket product meant as replacement for the stock pipes and 63.5mm is Supersprint "oversized."
I know what I've written is pedantic, but the point is, if you're comparing flow, 63.5mm to 60mm is different than 63.5mm to 55mm.
The slip fit end of the oversized sect 1 (v1 stepped) is actually 66.5mm to go over the 63.5 ends of the v1 stepped headers. It all adds up.Last edited by Tbonem3; 04-20-2022, 04:35 PM.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
Didn't plan on getting an exhaust yet but thanks for setting the GB up, I'm not going to pass this up.
I have 1 question though. I like the 63.5 stepped header into the 63.5 catted sec1. Section 2 twin pipe shows it's 63.5 also, will this bolt up to the stock muffler or a muffler of my choice?
Thanks
Originally posted by Wernd View PostDidn't plan on getting an exhaust yet but thanks for setting the GB up, I'm not going to pass this up.
Thanks
The 63.5mm headers are really only compatible with Supersprint's Section 1. You have 3 options - from expensive to affordable: HJS catted, Resonated Catless, Catless.
So it sounds like the V2 stepped headers aren't on the table with this offering and I'd need to order both the headers and a new section 1, as well as a new section 2 to see the benefit of the 63.5mm.
thanksLast edited by fattycharged; 04-21-2022, 10:14 AM.
Are the prices for the catted sport and race kits backward? Catless race kit costs more than catless sport kit, but catted sport kit costs more than catted race kit. And individually the sport muffler is cheaper than the race muffler. Am I missing something or is it not adding up?2003.5 ///M3 - Laguna Seca Blue - Black - SMG Delete
Ok, that was my question. The 63.5mm headers are only compatible with the new 63.5mm section 1, the SuperSprint HJS cats I currently have on the vehicle are apparently 60mm?
thanks
Originally posted by sina View PostAre the prices for the catted sport and race kits backward? Catless race kit costs more than catless sport kit, but catted sport kit costs more than catted race kit. And individually the sport muffler is cheaper than the race muffler. Am I missing something or is it not adding up?
The catted sport kit is indeed missing the 5% package discount, good catch. I can apply the discount after the order as I can't modify the live listing,
Originally posted by R717 View Post
Double-checking before I pull the trigger - the 63.5 mm hjs catted sec 1 will bolt up to the stock sec 2?2004 Silbergrau Metallic 6MT
Versus the OEM? It will have slightly more volume, but it's reported the 63.5mm resonated twin-tube section 2 from Supersprint helps eliminate rasp.
