Just got mine today. It was a quicker turn around than I expected. thank you fir setting this up!
Vincebar Group Buy 2021
Received mine today, the candy may mold over by the time it's actually installed. Thanks again Silde!
- Likes 3
Originally posted by ej257 View PostTo those doing DIY, where are you guys ordering / getting your epoxy and applicator from?
Got 2 for the Vince bar and underside plates.2003.5 E46 M3 Silver Grey/Cinnamon
Vince recommends Araldite 2014.Originally posted by ej257 View PostTo those doing DIY, where are you guys ordering / getting your epoxy and applicator from?
Technical Expert Dow Corning Distributor, Loctite Distributor, Henkel Distributor, Lord Distributor, HumiSeal Distributor, Silicone Distributor, Electronic Manufacturing, Aerospace Manufacturing, Lighting Manufacturing
Order Huntsman Araldite 2014 at Perigee Direct for high temperature epoxy gel with chemical proof durability in harsh industrial bonding.
2003 Imola Red M3 w/ SMG
I went EPOXY and rivet. A lot of members went with that as well and I spoke to my mechanical engineer cousin and confirmed its just as strong if not stronger.Originally posted by RawS54 View PostJust stumbled upon this...im gonna order through Vince directly but wanted to ask you guys epoxy/rivets vs weld version?
Originally posted by Tonggi View Postanyone have a soft copy of the install? I lost the print out. TIA
Greetings. Below you will find my latest project; being the COMPLETE rear subframe reinforcement. In this guide you will find EVERYTHING required to drop the subframe, perform the reinforcements, and bolt everything back including torque values and parts needed. This project is a result of a lot...
thannk you sir. those videos are great.Originally posted by Slideways View Post
https://www.youtube.com/watch?v=wwve...gf2PDXswy7qyl6
. Big thanks to Vince and everyone who participated!
