Sid's 2003.5 Silver Grey Speed Run
    Gave up looking for a CSL diffuser that was already painted SG and decided to go with a "Ameoba Wings" (Taiwan) diffuser.
    My friend's body shop had it paint matched and it looks great.
      Another mini journal.....
      So I decided to swap out my 2006 X3 for a 1993 525i touring as my new "old" daily, only issue is I have to rebuild the front end of the E34.
      Bought it from Portland IAAI and had it shipped to pretty much the other corner of the US; Atlanta.
      Click image for larger version  Name:	525 it.jpg Views:	0 Size:	115.5 KB ID:	171627
      Click image for larger version  Name:	PXL_20220602_015602512_2.jpg Views:	0 Size:	197.3 KB ID:	171628
      Immediately got to tearing apart the wrecked front end and getting rid of 29 years of grime.
      Click image for larger version  Name:	PXL_20220602_194240986.jpg Views:	0 Size:	223.8 KB ID:	171629
      I found an E34 part out in Alabama with all the parts I needed, and in the same color as well.
      I also changed out the VCG and painted the cover black.
      Click image for larger version  Name:	PXL_20220609_185333562.jpg Views:	0 Size:	231.4 KB ID:	171630
        Been a while since I posted here.....
        Ended up uninstalling the Dinan S3r kit and replaced it with a Haimus Racing CSL box.
        Click image for larger version  Name:	PXL_20221023_020342097.jpg Views:	0 Size:	226.0 KB ID:	208708
        Click image for larger version  Name:	PXL_20230225_012033028.jpg Views:	0 Size:	223.9 KB ID:	208709
        Click image for larger version  Name:	PXL_20230225_033653829.jpg Views:	0 Size:	234.4 KB ID:	208710
        Click image for larger version  Name:	Snapchat-233907582.jpg Views:	0 Size:	86.3 KB ID:	208717
        Had the injectors rebuilt while I was in there.
        Click image for larger version  Name:	Snapchat-1667377567.jpg Views:	0 Size:	81.1 KB ID:	208716
        Traded my pretty good-condition cinnamon seats for some absolutely perfect ones from a friend.
        Click image for larger version  Name:	PXL_20230211_172553307.MP.jpg Views:	0 Size:	175.1 KB ID:	208711
        Click image for larger version  Name:	IMG_20230307_003159.jpg Views:	0 Size:	115.5 KB ID:	208712
        My old CSL trunk is currently physically repaired and should be painted Silver Grey soon.
        Also finished rebuilding the E34 touring and put about 10k miles on it already. Couldn't resist throwing some BBS's on it.
        Click image for larger version  Name:	PXL_20220719_184613980.jpg Views:	0 Size:	160.0 KB ID:	208713
        Click image for larger version  Name:	PXL_20221217_161403853.jpg Views:	0 Size:	201.5 KB ID:	208714
        Click image for larger version  Name:	PXL_20220811_174059084.jpg Views:	0 Size:	200.9 KB ID:	208715
          The E34 fucks hard.
          2005 BMW ///M3
          Black6MT Daily
            But do you like BMWs?
            2003 Imola Red M3 w/ SMG
              Maybe.......
                How have the Part Shop Max subframe bushings been? I know they are just bushings but didn't know if there was anything to report back like hard installation or noises coming from them.
                  They have been great, and pretty easy to install. No complaints really.
                    Hi Sid, really enjoyed this build journal. Just picked up my first e46 m3 last week in SGM as well.
                    I was wondering if you could provide some insight on who you used for your body shop as I am located in Norcross, GA and would want to eventually repaint the entire car.
                    /// 2004 SG/IR - Build Thread
                      My friend's brother has done the body work for me so far but he is moving locations relatively soon. I can ask if he would be willing to take on the job eventually.
                        That would be great. Realistically, it probably wouldn’t be until later this year. I want to try and get a Karbonius roof installed but they have a 12 week lead time.
                          Got rid of the surface rust in the battery tray and painted it in silver POR15.
                          I need to do this in my car, can you tell me the steps you used? I was planning on using a wire wheel on the rust, sanding, prime, and rattle can.
                            Dremel wire brush would probably make quick work of the rust spots
                              I used a wire wheel as well but painted POR15 on with a brush instead of using a rattle can. I believe POR15 is much better at rust prevention and is way more wear resistant.
                                Right on, thanks!
