Sid's 2003.5 Silver Grey Speed Run
    That DMG bar Looks gorgeous
      Swapped out my SS street for a SS street with Hamann tips.
      So the swap you did was just to the Hamann tips? i.e., you're still rocking SS street exhaust?
      Nice work on the Euro bumper. I love mine.
        I didn't swap just the tips. It's a "fully-fledged" Hamann muffler which Supersprint made by taking an SS Street and welding different tips onto it. I could only find 2 places that had info on these; the listing where I bought this one, and a listing in Malaysia. It also seems they had a version with DTM style tips.
        https://www.zerotohundred.com/forums...xhaust.457985/
        https://forums.m3cutters.co.uk/threads/f-s-hamann-stainless-steel-exhaust-silencer-back-box.120614/
        Click image for larger version  Name:	hamann tips.jpg Views:	0 Size:	65.9 KB ID:	255499
          Siddhant Performance Parts
          2003 E46 M3 Titanium Silver / Black
          www.instagram.com/nextlvel
            Personally not a fan of the Black Dinan tips so decided to sand off the paint and polish them (not polished in this pic). I don't know what Dinan used to paint these tips but it took HOURS to get the paint off.
            Click image for larger version Name:	IMG_20210806_142536.jpg Views:	0 Size:	80.5 KB ID:	119414
            Got the exhaust in including the SS section 2 from the group buy (Thanks Epoustouflant ). I was a bit worried about the fitment since my SSV1s weren't perfect but the section 2 has perfect fitment.
            Click image for larger version Name:	IMG_20210806_220932.jpg Views:	0 Size:	119.2 KB ID:	119416
            Took some notes from Obioban and used the Inconel bolts from the OE headers to join the section 1 and 2.
            Click image for larger version Name:	IMG_20210806_232527.jpg Views:	0 Size:	72.9 KB ID:	119417
            Also threw on a CSF oil cooler.
            Click image for larger version Name:	IMG_20210806_142559.jpg Views:	0 Size:	133.9 KB ID:	119415
            I want to do the same to my Dinan exhaust. Did you just use a small polisher or was this a sandpaper and elbow grease job?
              I started with some pretty coarse sandpaper, that paint is quite tough and took a while to get off. Finished it off with a polish after all the paint was off.
                I got my Euro bumper back from paint and also had a CarboProject diffuser painted at the same time.
                Click image for larger version  Name:	bumper euro.jpg Views:	39 Size:	272.4 KB ID:	259463
                    would this car ever be for sale?
                      I don't plan on ever selling this car.
                        Few more small updates.
                        Swapped out the factory coolant reservoir for a Moroso tank.
                        Click image for larger version  Name:	moroso.jpg Views:	37 Size:	85.3 KB ID:	265541
                        Also installed the MAP sensor kit and had a CSL tune flashed. There is definitely a gain in low end power and responsiveness compared to Alpha N.
                        Click image for larger version  Name:	map.jpg Views:	275 Size:	72.3 KB ID:	265542
                        Threw on an Eventuri scoop as well.
                        Click image for larger version  Name:	PXL_20240528_015726027.jpg Views:	235 Size:	102.3 KB ID:	265983
                          I was not a fan of how the Moroso cap looked in the engine bay so I modeled out an "oe" style cover for it and printed it in ASA to withstand the heat.
                          Here is the file if anyone else is interested in printing one.
                          I can also ship them out if requested.
                            Still haven't done the Karb roof yet but have done a couple other mods in the past few months.
                            Tried out the PS reservoir expansion kit that the E9x guys seem to like. Tested it out on my E34 first and it seems to work so I threw one on the M3 as well.
                            Click image for larger version  Name:	ps expansion.jpg Views:	39 Size:	106.7 KB ID:	277733
                            Reinforced the sway bar mounts for a Ground control bar. (Edit: Didn't fit with Rally Road 996 Brembo lines. Touches the brake line elbow on lock)
                            Click image for larger version  Name:	gc bar.jpg Views:	33 Size:	146.4 KB ID:	277734
                            Painted in POR15 after*
                            Click image for larger version  Name:	bar rein.jpg Views:	33 Size:	85.4 KB ID:	277735
                            Decided to try out @Bry5on 's SSv1 brace, not sure if it made a difference yet but will know whenever I drive the car next (Edit: Brace definitely works)
                            Click image for larger version  Name:	ssv1 brace.jpg Views:	33 Size:	45.2 KB ID:	277736
                            Also, Dinan throttle bodies.
                            Click image for larger version  Name:	Dinan tbs.jpg Views:	16 Size:	187.1 KB ID:	290216
                            Click image for larger version  Name:	IMG_20240901_234855_898~2.jpg Views:	33 Size:	73.1 KB ID:	277737
                              Were you happy with how the epoxy came out for the sway bar reinforcements?
                              2003 E46 M3 - Alpine on Imola Build Thread
                                I guess if its good enough for my subframe plates, it should be fine for the sway bar mounts. Seems to works fine for a couple others as well.
