Casa de Mesa’s M3 color change from blue to blue
    The yellow calipers look even better with this blue
      Thanks! I like them better on this color too.
        That looks amazing! Wow!
        2003.5 BMW M3 Carbon Schwarz Metallic/Cinnamon 6 Speed – HTE Tuning | Kassel CSL DME | AA Headers | AA Section 1 | SS Resonated Section 2 | SS Race Section 3 | TMS V2 CSL Airbox | TMS Street Plates | Ohlin’s R&T Coilovers | Ground Control Front and Rear Sways | Ground Control Adjustable Camber Arms | DMG Autosport Pro46R | FreakyParts BBK Front | Porsche 996 Conversion Rear | CMP Stage 1 + 1.5 Reinforcement Plates | CMP Subframe Bushings | CMP RTAB’s | SGT CSL Bumper | SGT CSL Trunk | Dr VANOS
          have you considered using the shorter CSL specific dipstick? it's a little extra work to check your oil but no risk of a kinked dipstick or scratched airbox
            Dude it's looking so good!!! Love the color and, well, everything.
              You've made an excellent colour choice. Keep up the great work.
                Thank you! Appreciate that.
                Thank you sir! Still amazed at your front main seal tool. Such an ingenious design. Did you decide to change any aspects of it? Curious if the much bigger washer helped or not, that might have been all that's required.
                Hi to my boy Nobu 😀
                The respray was a bit of a gamble and that first day showing up at the shop after it was painted was a bit tenuous... until I saw it! I'm super happy with the color so the gamble (for me) paid off! Thank you!
                Man, funny you should ask that. In short, YES.
                I do not like how the bent dipstick mod turned out. It works and it's out of the way, but given how little of a pain checking the oil level is, even with needing to remove the front half of the plenum (& snorkel), I'm likely going to go the CSL dipstick route. I don't like having to hold the top of the dipstick tube to steady it while pulling the dipstick out. Seems like after time, something will give way as it's totally unsupported up top and that's a lot of leverage acting on the bottom of the dipstick tube. I haven't seen any great ideas on how to make this work that support it from the top and don't look Fischer Price.
                  I routed mine behind the wiring harness plastic and against the DME barrier on both my cars. Didn't have to bend it and it's sturdy. Also doesn't interfere with strut bar. Crappy pics...
                    Rob for the win. I will try this. Thanks for posting these.
                    I see it's routed between the aux H20 pump hoses. Are you getting rub-through from metal on rubber? I don't like it when two parts not designed to rest against each other do exactly that. One or both parts inevitably wear in an unintended way. It could just be this photo...
                    Regardless, I am definitely going to try this before buying the CSL dipstick. There has to be a way to isolate these two parts.Thank you!!
                    EDIT: In thinking this through more, with the top of the dipstick fixed to DME housing, and the bottom mounted to the oil pan, as that motor twists, are you seeing any signs of wear at the oil pan? Or at the DME housing?
                    I'm presuming "no" given you're running this on both your cars.
                      Meguiar's #57 Marine & RV Vinyl & Rubber cleaner & protectant
                      Meant to mention this in a previous post. I found out about this stuff from Tbonem3 . Tyler, this stuff is gold! For any re-used plastic and rubber parts, after cleaning them with Simple Green, I soaked them in this stuff. Here is a pic of the first coating of #57 on the pusher fan. You can see where on this piece, it soaked into the plastic but was a little blotchy. For almost ALL pieces, this didn't happen and it soaked in evenly. But for some pieces, it only took a second soaking with time to absorb into the plastic before wiping clean again and the parts looked uniform and awesome. Literally in some cases, better than new.
                      HIGHLY recommend this stuff for all exterior plastic and rubber bits. This has become my Frank's Red Hot Sauce - I put that s*** on everything.
                      Click image for larger version  Name:	IMG_20220401_161717.jpg Views:	73 Size:	219.7 KB ID:	173571
                      New and/ or refurbished trim
                      Despite the trend to go back to chrome with kidneys and grills and such, I decided to go gloss flat black everywhere. With this blue, my opinion is chrome would look odd. I have always like black trim on lighter color cars - the contrast checks all the visual boxes for me.
                      So while I did buy all new exterior door and window trim in gloss black:
                      P/N: 51327890453 Gloss Shadowline Trim - Left door
                      P/N: 51327890454 Gloss Shadowline Trim - Right door
                      P/N: 51367891911 Gloss Shadowline Trim - Left quarter window
                      P/N: 51367891912 Gloss Shadowline Trim - Right quarter window
                      ...I wasn't willing to cough up the $2600+ per side for the gloss shadowline trim that runs from the A-pillar back the C-pillar and terminates at the base of the Hofmeister kink. The matte black ones from my car were in really good shape, right down to the rubber seals, so I asked Vintage Restoration if they could paint them gloss black. Yep!
                      Here they are, a bit dirty, but having these mounted to the car - TRIM ON THE CAR!! - feels pretty incredible at this point in the project.
                      P/N: 51717030845 Gloss Shadowline Trim - "A to C pillar" - Left
                      P/N: 51717030846 Gloss Shadowline Trim - "A to C pillar" - Right
                      Click image for larger version  Name:	IMG_20220515_163052.jpg Views:	68 Size:	162.5 KB ID:	173572
                      Click image for larger version  Name:	IMG_20220515_162914.jpg Views:	70 Size:	144.5 KB ID:	173574
                      Door weatherstripping going in
                      All cleaned and then treated with the Meguiar's #57. Stuff is awesome.
                      A little tip on this stuff. After letting it soak in for a few days, come back and wipe them clean again with a dry cloth. It will remove any minor (very minor) residual protectant that didn't soak in and as such, won't attract dust/dirt.
                      Click image for larger version  Name:	IMG_20220521_101451.jpg Views:	65 Size:	131.6 KB ID:	173573
                      Click image for larger version  Name:	IMG_20220521_102503.jpg Views:	68 Size:	77.5 KB ID:	173575
                      Click image for larger version  Name:	IMG_20220521_101707.jpg Views:	67 Size:	130.6 KB ID:	173576
                      Click image for larger version  Name:	IMG_20220521_101439.jpg Views:	67 Size:	167.7 KB ID:	173578
                      Quarter windows
                      Quarter windows back in!! Another huge milestone. After staring at a shell for so long, seeing side glass back in the car is monumental.
                      Click image for larger version  Name:	IMG_20220521_132834.jpg Views:	68 Size:	118.1 KB ID:	173577
                      Reassembling the doors
                      This wasn't as bad as I thought it would be, but mostly thanks to (once again) robgill who warned that when he did this, he wished he took more pics. I have probably 200 pics of just the driver side door!
                      The vapor barriers in these pics below are the original ones, and somehow, that goopy sealant BMW uses is reusable if you take your time on removal. I know the fact that it's reusable is pretty well documented elsewhere on the internet, but I'm glad I took the time and went slow during removal. I couldn't find a replacement sealant that BMW uses hence why I opted to go slow and on removal, but it sealed right back up way better than I expected. I used isopropyl alcohol to clean the surface where the sealant would go and it worked really well.
                      Click image for larger version  Name:	IMG_20220515_112955.jpg Views:	69 Size:	114.5 KB ID:	173579
                      Click image for larger version  Name:	IMG_20220522_144700.jpg Views:	67 Size:	160.6 KB ID:	173581
                      Click image for larger version  Name:	IMG_20220522_144254.jpg Views:	69 Size:	171.7 KB ID:	173580
                      New exterior door handle seals.
                      Click image for larger version  Name:	IMG_20220517_182620.jpg Views:	66 Size:	69.1 KB ID:	173585
                      Slicktop stuff
                      A parting shot to the Slon Workshop carbon roof bow. Got all the interior wiring and side curtain airbags back in place. Got the slicktop coat hangers and associated hardware mounted up. Of course all the wiring (except speaker wires) was refreshed with new Tesa felt tape because I bought 5 rolls of the stuff and man does 1 roll cover a lot of wiring!
                      A huge shout out to my buddy Don who came down from PA and helped with this part. His beautiful (but dirty in this shot, no judging) E36 M3 is one of the reasons I decided to move forward with this project. It's originally Hellrot Red, but was resprayed and the car looks absolutely mint. This is a horrible photo below...
                      Click image for larger version  Name:	IMG_20220522_150139.jpg Views:	68 Size:	129.0 KB ID:	173582
                      Click image for larger version  Name:	IMG_20220522_150217.jpg Views:	68 Size:	177.9 KB ID:	173583
                      Hellrot gloriousness...
                      Click image for larger version  Name:	IMG_20220424_064147.jpg Views:	66 Size:	121.4 KB ID:	173584
                      Front bumper stuff
                      Got everything I needed to install behind the Euro bumper done. Last minute decision, I decided to reuse the existing windshield washer reservoir. I will eventually come back and mount up the E36 tank in the drug bin per one of my earlier posts (using the Brey Krausse adapter), but I was missing some caps, plugs and fittings I needed to make it work. Getting those was going to take a while and at this juncture, it was holding up progress. My solution until then it to keep the bare minimum amount of washer fluid in the reservoir.
                      Also, after missing the motor install due to bronchitis, my father came down and helped with a lot of this part of project also. Also like I've said earlier in this thread, we are car family going back to when cars started to become a thing (early 1900s). Having my dad's help and expertise was invaluable. Thank you Dad!
                      It's starting to look like a car again...
                      Click image for larger version  Name:	IMG_20220515_162708.jpg Views:	68 Size:	179.3 KB ID:	173588
                      Click image for larger version  Name:	IMG_20220515_162725.jpg Views:	68 Size:	98.5 KB ID:	173587
                      Click image for larger version  Name:	IMG_20220515_162842.jpg Views:	67 Size:	143.6 KB ID:	173586
                      License plate mount (trunk)
                      Here's a few shots of my method to get this thing mounted up. It's a bit anxiety inducing drill into freshly painted carbon. After marking the hole locations, used a center punch to dimple the paint/trunk. I just used my hand a pressed in. I then took the smallest drill bit I had, and slowly "drilled" into that center-punched dimple by hand. As in, held the drill bit in my hand and slowly made the initial marks you see. After I had a good start, I then switch to an actual drill bit and very slowly with very light pressure, drilled into the trunk...
                      I still love that this trunk is serial #13.
                      Click image for larger version  Name:	IMG_20220521_162128.jpg Views:	66 Size:	70.8 KB ID:	173589
                      Click image for larger version  Name:	IMG_20220521_161930.jpg Views:	65 Size:	86.3 KB ID:	173591
                      Click image for larger version  Name:	IMG_20220521_161947.jpg Views:	66 Size:	39.0 KB ID:	173590
                      Click image for larger version  Name:	IMG_20220521_165534.jpg Views:	67 Size:	96.7 KB ID:	173592
                        Really nice build ! Great job! Color looks like a richer version of LSB with more depth
                        2007 Imola Red Z4M Coupe
                          Hi to my boy Nobu 😀
                          Thanks! I ended up sending it to someone else with a larger washer and it worked fine. Then I sold it permanently to someone else so I guess it's working fine Have not had time to make a new design!
                          Keep up the good work!
                            I did something similar, but passed my dipstick under that plastic harness bracket thing. Same deal, no bending and pretty sturdy.
                            Shitty pic as well:
                              It’s hard to tell from your pics but it looks like you might still have the sunroof coat hook brackets in there. Don’t forget to replace with the non-sunroof versions if you haven’t already. Otherwise the coat hooks won’t fit right or work correctly, and certainly won’t screw back in. Stupid little detail that kept my entire interior apart an extra five days or so while I waited for them
                                Got it! Earlier in this build thread, I mention that you have the FMS tool for rent. I can edit the post if you're not planning on renting one out anymore.
                                Shitty pic as well:
                                The pic is perfect! I see exactly what you mean. Did you attach it at the top or does the way you routed it provide a friction fit so you don't need to?
                                And from your other post somewhere on here, I see what you mean about you also having that little air gap with the BMC CSL filter. It's literally in the same exact place!
                                Click image for larger version  Name:	IMG_20220521_185029.jpg Views:	0 Size:	184.8 KB ID:	173687
                                Those are the slick top coat hook brackets!
                                51168223047 Left
                                51168223048 Right
                                Thanks for calling that out though. I saw you post that about yours and man, not having those stupid little brackets and having them holding up progress would have driven me nuts!
