Liam821's e46 324i k24/dct/turbo build
    Man that engine looks tiny in there. Cabin air filter housing makes the S54 look like a 4 cylinder... and the K look like a 2 cylinder.
      Front mid-engine! haha
      And yeah, it looks tiny in there, especially with the cabin air filter housing.
      Spent more time pulling out the rest of the interior and cleaning...
      Found their food stores...thankfully they kept that area clean, it just had food and vacuumed right up
      Everything else has been removed now
      I'm happy to report that the smell has mostly left with the interior. I'm gonna do some more cleaning this weekend and see what's what. Worst comes to worst, I'll send this shell to the big crusher in the sky and pick up another one.
      Japanrot Red E46 330i Msport k24/dct/turbo Build Thread
        Nice lack of fold through!
          Just joining the thread, can't wait to see the progress!
            I first thought I was going to do a full dry sump system, but after talking with Robert at Tractuff I'm going to do a wet sump external oil pump solution. Basically, I'll chop the front off the stock oil pan (where the OEM oil pump lives) and move the oil pickup to the back - I'll make the back wider so I can keep ~5 quarts of oil.
            Robert@Tractuff's e46m3 with a k-swap.
            Yes! Thanks! I wanted a non-folding rear since the chassis is much stiffer and almost on pair with an e46m3.
            Same! The replacement transmission mounts should come in the mail tomorrow. I'll start working on building engine mounts this week.
              Got the new e89/e92 non-m DCT transmission mount in the mail today! Here is the side-by-side with the e9Xm3 style mount. The smaller one is the e89/e92 non-m one. If you're wondering, yes, both mounts fit either transmission. All four transmission versions are essentially the same except for gear ratio and bell-housing combinations. They all feature the same input spline, filters, and oil pan. There are two V8 bell housings (e9Xm3 short-ratios and the F10m5 long-ratios) and two slant/6 bell housings (135/335/z4 short ratios and F80m3/m4 which was a long ratio). My gearbox is an e92m3 short-ratio because it had the best support from the DME I'll be using (MaxxECU) and has the short ratios. She's thick three c's here big.
              SeemsLegitGarage trans crossmount with e89 non-m mount
              aannnnddddd it just doesn't fit... the transmission is back as far as it goes and is hitting the transmission tunnel. You can see the bolt holes just don't line up.
              Lifetime fill lolz
              What I think I'm going to do is put a 10mm spacer on the back of the transmission mount to push the engine and trans forward 10mm. I'd rather have the engine as far back as possible, but moving it 10mm still puts the engine in a good place, will allow me to use a stock Honda valve cover, and the transmission fits. It puts the front of the engine about 21" from the rear firewall.
                Oooo exciting build series!
                At least with pushing the engine forward 10mms you can access the engine oil fill cap without taking off the cabin filter housing. Win win! =)
                  Got 10mm spacers in the mail and 10mm longer M10 12.9 grade bolts (M10x40)
                  They'll go on the transmission mount like this. If I had a slant 6 bell housing (135i/e92/f80m3) dct I probably wouldn't need to do this, but the s65 bell housing is really wide
                  Mount installed with the spacers
                  Finally bolts right up!
                  The engine is just about right where it needs to be. There is a 1 degree up angle towards the back of the transmission. So I'm either going to have to raise the motor a few mm or lower the back of the transmission a few mm. I'm probably going to lower the transmission just a tiny bit as I'd like to keep the engine as low as possible.
                  All the room for a big turbo setup! I was eyeballing turbo placement with an EFR7064 turbine housing off my race car.
                  The engine is as far back as I can get it. Almost all behind the steering rack
                  Just squeezes in under the factory hvac cawl. I'll probably end up using a low-profile valve cover anyway since getting the valve cover on and off is tight with the stock one.
                  The dct does not stick below the frame rails, thankfully
                  It's a massive transmission
                  I've done a 3d scan of the engine bay and will start designing motor mounts in Fusion360. I'll post some pictures of how that goes.
                    What 3D scanner are you using?
                      Apple iPhone 14 ProMax! I'm using a piece of software called Scaniverse, it's pretty great.
                      Here is a scan of a temporary k24 I have, checkout the nice inspection window! It's accurate down to about a mm, which is fine for making motor mounts and such.
                      Here is an idea of what a scan looks like
                        It's funny how the iPhones have LIDAR, and it gets used for... almost nothing.
                          Yeah, It's used for FaceID and basically nothing else.
                            Does the app your using use the front or rear LiDAR?
                              The iPhone LIDAR is pretty garbage for scans in my experience. The rear LIDAR is useless for anything other than walls in your house and the front one doesn’t map very accurately. Photogrammetry scans seem to come out way better.
                              Very cool project build you’ve got going here, I hope you corner weigh it when it’s done!
                                You can use either one, the front lidar sensor is more detailed but not as wide and extremely hard to use because you can't look at the screen very well when you're taking a scan. But the rear one is more than detailed enough for most car part design or 3d model or objects.
                                For instance, here is a fountain my wife liked. It's about 20" tall. From the scan you can directly 3d print it or import it into Meshmixer or Fusion to modify it.
