Vegas 2006 Imola 6MT Coupe Refresh
    I love Imola!!!
      The rebound on my factory strut is too soft LOL!
      Off to the landfill
        The back felt loose and tracked bad on the highway. Just as I though, the RTAB and ball joints were shot. Given the mileage, the struts were past due too.
        RTABs out first.
        Click image for larger version  Name:	0F459AF2-620B-44E9-A175-8F622C1A6512.jpeg Views:	0 Size:	114.4 KB ID:	48624
        Went with OE plus limiters
        Click image for larger version  Name:	470A8897-7E4C-4F15-ADF2-A2551A9A0CC7.jpeg Views:	0 Size:	167.4 KB ID:	48632
        Click image for larger version  Name:	20A8324D-E2D3-499D-A707-5E8CCB35B10E.jpeg Views:	0 Size:	133.5 KB ID:	48627
        Next remove the old ball joints
        Click image for larger version  Name:	A07EB98C-F425-495F-9B67-F19BA43DFA00.jpeg Views:	0 Size:	90.4 KB ID:	48621
        Click image for larger version  Name:	5A024F03-1F81-4CE2-943C-9E02169DE43D.jpeg Views:	0 Size:	101.2 KB ID:	48623
        No shots of the install, doh!
        Dinan springs going back in place of the H&R
        Click image for larger version  Name:	61ED3012-EF94-4578-BEF9-CD048E816528.jpeg Views:	0 Size:	140.1 KB ID:	48625
        Koni yellow
        Click image for larger version  Name:	B96C6EC4-5D15-4012-9BCB-F2945CB1E068.jpeg Views:	0 Size:	162.0 KB ID:	48628
        Rebuild calipers and installing SS lines
        Click image for larger version  Name:	C400866E-BFD4-4EB4-8A2D-9D9F0BB9B1D2.jpeg Views:	0 Size:	188.3 KB ID:	48630
        Cleaned it up a bit and buttoned it back up plus bled the brakes throughly.
        Click image for larger version  Name:	B8062A36-0D3B-4570-9892-A01C92E73FB4.jpeg Views:	0 Size:	139.3 KB ID:	48629
          Great Job saving this car. So much better now.
            Front brake rebuild. I’m not replacing the front shocks and springs just yet. I will be doing my rod bearings in the next two weeks and will wait to replace them when I drop the front subframe.
            Front rebuild bits
            Stainless lines peaking through. I gave the front wells a quick wipe down while I was there.
              Time to tackle the remainder of my projects to get it road worthy.
              Rod bearings
              Front strut assemblies with new everything
              Sway bar bushings and links
              FCAB
              Lower control arms
              Steering guibo
              Engine mounts
              Reinforcement plate bolts
              New radiator
              Rod bearings were pretty straight forward but tedious. The 105 degree TTY was a arm workout!
              Click image for larger version  Name:	EF4BA0F9-E3CA-4129-B941-15AD4694E970.jpeg Views:	0 Size:	170.8 KB ID:	52728
              Click image for larger version  Name:	F384366F-66B0-43AE-AF7B-0FA5991B795A.jpeg Views:	0 Size:	181.4 KB ID:	52685
              Click image for larger version  Name:	63AC39E9-E56E-44CF-8120-B262E18B3EEF.jpeg Views:	0 Size:	119.4 KB ID:	52684
              Click image for larger version  Name:	D75C355E-7820-4877-B2E4-7EA885058DAF.jpeg Views:	0 Size:	101.3 KB ID:	52682
              Click image for larger version  Name:	33B4278A-2752-45E8-8F0F-05629C008903.jpeg Views:	0 Size:	191.2 KB ID:	52686
              Oil pump bolted back up
              Oil pan buttoned back up
              Cap side 1 - 3
              Click image for larger version  Name:	662611AB-72EE-4F89-A486-FE7BAE2D7135.jpeg Views:	0 Size:	191.1 KB ID:	52690
              Rod side 1 - 3
              Click image for larger version  Name:	1B688F7A-430B-4A0A-B309-68646C40873E.jpeg Views:	0 Size:	199.7 KB ID:	52689
              Cap side 4 - 6
              Click image for larger version  Name:	15D62B14-3597-4551-BB87-94F6D59EE098.jpeg Views:	0 Size:	189.6 KB ID:	52688
              Rod side 4-6
              Click image for larger version  Name:	B5D2242E-D35C-4F50-AF84-034E202B2348.jpeg Views:	0 Size:	186.4 KB ID:	52687
              Strut assemblies
              Click image for larger version  Name:	90814F90-C9FA-470C-921A-3E48C071E51F.jpeg Views:	0 Size:	307.3 KB ID:	52696
              Click image for larger version  Name:	A12BDC87-499D-4A60-99C3-D1699C09ACE7.jpeg Views:	0 Size:	142.5 KB ID:	52695
              Sway bar refresh
              Click image for larger version  Name:	CAFE0B57-8E75-4843-91A4-A6B5A9373CE0.jpeg Views:	0 Size:	289.3 KB ID:	52697
                FCABs, lower control arms, motor mounts
                Lemfoerder vs BMW
                Click image for larger version  Name:	40955B03-DEB7-4009-A9B3-23321215C934.jpeg Views:	0 Size:	82.8 KB ID:	52700
                Click image for larger version  Name:	BA2C5D44-5C10-408C-B149-DC3E5DC64B19.jpeg Views:	0 Size:	180.5 KB ID:	52701
                Lower control arm and FCAB mounted up
                Click image for larger version  Name:	A19EDAEC-BD2E-478E-A735-EDF8978C842F.jpeg Views:	0 Size:	202.8 KB ID:	52705
                Steering guibo and motor mount in place
                Click image for larger version  Name:	73BAFA03-4295-40D9-BC8F-A5EB04474D22.jpeg Views:	0 Size:	156.3 KB ID:	52704
                Assembly ready to install
                Click image for larger version  Name:	679899B9-D7FF-4D36-BFF0-B1C55DFE76BE.jpeg Views:	0 Size:	171.1 KB ID:	52702
                Motor mounts severely smashed!
                Click image for larger version  Name:	8A6D0867-653B-4EAC-A9CD-AA4117C80CEE.jpeg Views:	0 Size:	209.2 KB ID:	52706
                Click image for larger version  Name:	D507BA32-6B50-4E2A-A096-56D8CDF626FF.jpeg Views:	0 Size:	283.3 KB ID:	52707
                Oil pan reinstalled
                Click image for larger version  Name:	903CCF10-42B1-4AA6-84E8-01BCAE1478A9.jpeg Views:	0 Size:	174.5 KB ID:	52708
                Subframe assembly mounted back in place
                Click image for larger version  Name:	5475C1CD-52F4-44B6-BAE2-B4DC1BD68C37.jpeg Views:	0 Size:	156.6 KB ID:	52709
                Click image for larger version  Name:	2D8389CA-FD58-4B86-92EB-49597F941C7B.jpeg Views:	0 Size:	153.0 KB ID:	52710
                Click image for larger version  Name:	243DE80A-487F-4048-8EB7-3D6656C2EC7F.jpeg Views:	0 Size:	139.9 KB ID:	52711
                Buttoned back up
                Click image for larger version  Name:	89E2AE15-2615-4AA8-B991-93A38326BB34.jpeg Views:	0 Size:	118.9 KB ID:	52712
                Click image for larger version  Name:	3DB37A5B-E48B-49D6-B3D6-5E09630AEE44.jpeg Views:	0 Size:	118.1 KB ID:	52714
                Click image for larger version  Name:	D8B1A761-5307-4D4C-81D8-DB1D9821D969.jpeg Views:	0 Size:	131.8 KB ID:	52713
                Click image for larger version  Name:	EF71C644-ABDF-4F92-8FDD-063CC256AD23.jpeg Views:	0 Size:	125.2 KB ID:	52715
                New o-ring for the PS reservoir
                Add oil
                Click image for larger version  Name:	5B86DBD5-3AC1-4A3B-918C-E0EC8504C100.jpeg Views:	0 Size:	134.7 KB ID:	52716
                Let it warm up and check for leaks. Topped off oil and power steering ATF. All looks good and took it out for a spin. So nice and tight!
                  I replaced the radiator as it was the last piece of the cooling system left to replace. I was previously getting temperature creep while under load. Not enough to overheat but not how it should behave.
                  Bled out the cooling system and added distilled water and BMW blue. Problem is solved!
                    The aftermath
                    Not everything but a good chunk of it
                      I only got one key with the car so I ordered another master and the plastic backup.
                        Hot Damn!! Nicely done, talk about a refresh!
                        Thanks for documenting with photos and sharing with everyone. The photos of the various caps, connectors, and clips being replaced was really satisfying to see.
                          ^^ Thanks! Lots of work but it rides, handles and runs excellent now. All it needs at this point is some PDR in a couple of spots and paint correction.
                            Nice work, love how you "demodded" it, the old wrap and trunk aren't great.
                            Question about the fabric dye, I've heard of a couple people recommending the one from simply spray, where did you buy it?
                              I originally used it 5 years ago on my old M. This time around it was much harder to find. Here is the seller I used.
                                Agreed, great journal here. Big fan of how you're restoring this car back, nicely done OP!
                                Rich | 2001 E46 M3 | Alpinweiss & Imolarot | 6MT
