Obioban's 2005 IR/IR Coupe
    Ha. The stickers have double purpose-- hide the Porsche logo and tell me the caliper temperatures :P
    I have two graduated cylinders, connected by a tube at the bottom with 1/2" rubber fish tank line. I put water with food coloring (to make it easier to see) in there, and fill them both ~3/4 full. I shim under till both cylinders read the same, at which point I know they're level. I try to figure out which scale is the highest, and then use all the others to compare to that (shimming the others up). Once everything is shimmed up, I zero the scales so they don't contribute to corner weights.
    As shims, I use whatever the cheapest vinyl floor tiles I could find at Home Depot were (IIRC it was like $30 for 100 of them). They're ~1mm thick, so I can get reasonable leveling, and they're slippery-- so when I raise/lower the car, it doesn't get stuck high with the camber curve, and if I, say, adjust camber, I'm not fighting the friction of the tire on the scale-- the floor tiles just slide against each other.
    I'm about to put porsche brakes on, and couldn't be bothered with fiddling with the logo/repaint either! Did you get track pads sorted out through FCP? They seem to be out of stock of the good stuff for 6 months or so. My last conversation with a rep was that DS11.1's were backordered from the factory, not that they weren't going to carry them any longer.
    Great idea on the vynil floor tiles, I'm going to try that out! Do you level left right/ front back/cross? Could you use 4 cylinders and not have to level the pads multiple times?
      Haven't needed replacement pads yet, so will cross that bridge when I come to it.
      I started out with 4 cylinders, but it was way more difficult that way. With 2 cylinders, I know what the level is when scale. With 4, whenever I would change one all 4 would change, and I'd have to figure out what the new equal amount should be. Plus more tubes to trip over and fluid to fill. It was just a mess.
      With the new system, I just leave one on the highest, and then compare, one at a time, each scale to that. Quick, minimal fuss, easy to determine if level, less stuff to store.
      ... when we move, I'm going to use them to level my new 4 post lift and then probably get rid of them. Once I know the lift is level, they are no longer useful.
        Originally posted by blazenXLT View Post
        Interesting - I run 17x9.5 et35 all the time and have been thinking of a BBK upgrade soon, but I hate to buy something and have to just hope that it fits. I thought PFC made a BBK for fitting in a 17 but bimmerworld shows it as not available. Haven't done any more research though...
        On the garage I'd only offer the standard advice - you can't have too much space, power or light. On light I did ok in our build, but I do wish I'd added more outlets. I did run 220v to two places, so that should cover me for any future lifts, compressors, or EVs. And like I mentioned before, the space where I'd put a lift is 8 inches of 4000 psi reinforced concrete. I'll have to post up some pics in my journal thread.
        Well, if you hold off on brakes till the 17x9.5 ET35s ARC-8s arrive, I can tell you if they'll clear the 996 brakes. I also hate to buy with the hope that it'll fit, but I couldn't the answer find the answer anywhere and Apex said I could return them if they don't.
        I'll be running 220v for sure-- Lift, air compressor, and realistically EVs are going to take over while I live in this house.
          gotcha, that makes sense. sometimes simple is best.
            I have attempted to bring my mod list up to date. There's probably some things I'm missing, but... it's closer than it was.
            Engine:
            OEM ( Die Wethje) CSL Airbox
            Schrick 280/272 cams
            TMS pullies
            Dr VANOS cryo treated exhaust hub
            Beisan systems lifetime VANOS sealing plate o-rings
            Beisan systems lifetime VANOS solenoid
            Beisan oil pump disk
            Beisan VANOS rattle repair kit
            Beisan VANOS seals
            Beisan timing chain tensioner guide
            TurboToy (modified ARP) cam bolts
            updated BMW high pressure vanos oil line
            lifetime CPV o-ring
            Exhaust:
            SuperSprint V1 stepped headers (swaintech coated)
            SuperSprint HJS catted V1 Section 1
            SuperSprint resonated twin tube section 2
            SuperSprint Street muffler
            Engine Management:
            CSL Engine Management
            MCCHIP-DKR Dyno tune
            OE CSL IAT
            OE CSL Map rail/sensor
            Aux/clutched fan replaced with ecu controlled (using Z4M values) spal fan
            SMG shift lights turned on
            post cat 02s turned down but left on (ready)
            secondary air pump sensor disabled
            cold start sequence disabled
            non sport throttle mapping
            sport button disabled for future alternate use
            sport mode memory enabled
            EGT tweaked for HJS Cats' allowable max temps
            Top speed limiter removed
            Dyno limiter removed
            CSL warmup light values
            Suspension:
            Fat Cat Motorsports Stage 3 Coilovers
            Springs: 375 FL, 350 FR, 700 RL, 650 RR (equal frequencies left/right, 1.97hz front, 2.10hz rear, 75% front roll couple with sway in middle of adjustment range)
            Corner balanced and preload dialed out, with equal ride heights left/right with me in the drivers seat
            Ground control street camber plates
            Ground control street RSMs
            Ground control Front sway/bushings/brackets/end links
            CSL Rear sway/bushings/brackets, with home made adjustable end link
            Sealed monoball RTABs
            Bimmerworld sealed monoball rear adjustable camber arms
            CSL Kingpins
            Steering
            ZHP/yellow tag steering rack
            25% assist reduction by shimming pressure regulator
            CHF-11 conversion
            Alcantara steering wheel
            Brakes:
            817.3 DSC unit (CSL)
            Porsche 996 calipers
            CSL/ZCP/Z4M rotors (FCP)
            stainless lines
            OE Porsche Street pads (FCP)
            track pads (FCP)
            Castrol SRF (FCP)
            Hard Motorsport Brake Ducts
            Hard motorsport backing plates
            Body:
            Evolve CF roof
            Vorsteiner CSL trunk
            Fucy CSL diffuser
            Gunmetal grills/gills
            Depo smoked front corner lights
            35% tint (3M)
            vinyl M stripes on trunk badge (stock colors, less prone to fading)
            modern BMW wheel center caps
            shark fin removed
            OEM driver’s side keyhole cover (to deter thieves)
            Wheels:
            18" RAC RG-63s in gunmetal (street)
            17" Apex ARC-8s (track)
            TMS 75mm studs
            Lights:
            TFX projectors
            55w bulbs/ballasts/ignitors in 4300k
            85w halogen highs, programmed to come on with the xenon highs
            Outer brake light ring enabled for normal braking
            Brake lights programmed to strobe under hard stops
            e9X LED license plate lights
            Interior:
            Cobra Nogaros in Imola Red leather, with factory heating pads install and adjustable lumbar
            Brey Krause Mounts on factory e46 manual sliders
            Brey Krause Rear deck harness mounts
            Alcantara wrapped header liner
            Alcantara wrapped pillars
            Alcantara wrapped rear deck
            Alcantara wrapped steering wheel
            imola leather wrapped center console
            imola leather wrapped arm rest
            imola leather wrapped ebrake book
            Z8 ebrake handle
            M3 oval interior mirror retrofit
            Stereo:
            100% of factory stereo, mounting brackets, and wiring harness deleted
            Avin Avant 4 with speakers plugged in directly to unit
            Wireless CarPlay module
            Chassis:
            Vincebar, epoxy/rivet under floor version
            TMS subframe reinforcement kit with extra reinforcements
            BMW structural foam in subframe cavity
            updated BMW diff mount bolts
            CMP subframe raising solid mounts
            front strut tower inserts to remove slots
            Slonik chassis reenforcement plate
            Misc:
            Wavetrac differential
            Brail GU1R lithium ion battery (6 lbs), mounted in the engine bay to eliminate 6 lb battery cable
            Entire factory stereo (inc wiring harness, mounts, etc) removed
            Light weight (2 speaker) stereo powered by head unit installed
            Avin 9" touch screen head unit install (wireless CarPlay 99% of the time)
            CSL Cabin air filter housing
            Auto Solutions SSK
            RE Transmission mounts
            Hella Horns
            CDV delete
            VAG grocery bag hooks
            CSL Aux coolant pump
            Washer tank swapped for e39 high intensity washer tank
            e39 washer stalk for extra button to toggle M Track Mode while preserving on quick DSC off and steering wheel controls
            Coding (non comprehensive highlights):
            CSL oil level display (in cluster) enabled
            M track mode enabled
            Strobing shift lights
              I have a binder that is at least 150 to 250 pages with all receipts and a detailed job description of every job I have (and the one shop I occasionally use) completed. Even has a table of contents and an excel spreadsheet so I can see exactly what I've spent. 0 out of 10, don't recommend knowing those numbers lol.
                I have very intentionally never slightly thought about that.
                  Street review of wavetrac: indistinguishable from stock.
                  No track time on it yet.
                    I did a bunch of mods over the winter. The most significant (for me, anyway) was the Fat Cats suspension.
                    Because of moving, it's been hard to make actual progress on getting the car 100% (was driving for a while with no sway bars connected, etc). But, as of last week I'm installed, bump/droop ratios optimized, corner balanced, aligned, corner balanced again, and preload dialed out. I've put ~100 (street only so far) miles on the car, and and comfortable giving very early impressions.
                    My complete setup is as follows:
                    Fat Cat Motorsports Stage 3 Coilovers (every option they offer)
                    TMS Sealed monoball FCABs
                    CSL Kingpins
                    I'm running at 60% bump, 40% droop up front, with a .5" rake (seem to be optimal for high speed oversteer/understeer), which puts me at ~14" front, 13.5" rear. In terms of alignment, I'm at -1.5 up front (this will be pyrometer based set more negative on track) and -2.0 rear (this will be left alone on track). I'm super psyched to have a setup that lets me run high enough to have a reasonable street camber, with the CSL kingpins-- should be a pretty killer camber curve and let me get away with meaningfully less static camber on track! Rear geometry should also be pretty good, with the CMP bushings raising the subframe and minimal drop. My geometry is also pretty rigidly held, as the only bushings in the entire setup are rear upper control arm inside bushing-- everything else is a sealed monoball (shock mounts and drivetrain mounts are still bushed/stock, so NHV is pretty minimal).
                    Onward to initial street impressions of the FCM setup:
                    The only word I can think of to describe the car is unflappable. Nothing seems to phase it. If you've ever driven a car with too much tire (the level of grip is more than the suspension can deal with), this feels like what the opposite would be. The closest analogy that fits is a stock FRS/BRZ/86, on the default prius tires-- only with PS4S levels of grip.
                    It is remarkably different than any setup I've driven before. And I've been all over the map-- Motons and JRZs on the e36 track car, TCKs and Ohlins on this car, Stock springs with Koni yellows on the M5, Dinan springs with Koni yellows on the M3 wagon. I can't say it definitively till I've been on track (after which I'll make a dedicated thread about the setup), but so far this setup feels faster and easier (to drive) than any of the above. Plus, I'm excited to have a setup that just valved for my specific corner weights and spring rates, so I don't have to mess with adjusting shock valving before/during/after track events. It's just correct for the car.
                    I'm pretty excited for this setup-- don't think I'll be changing again. I look forward to seeing what it's like on track!
                      Congrats on reaching this point. I'm surprised you're on poly bushed camber plates and rsms though.
                        The monoball camber plates are just too much NHV for the amount of precision they add, for me.
                          Ya I'm concerned (I'm moving from poly tms street plates to vorshlag). Oh well
                            Awesome to hear you finally got this installed!! What brand and size springs did you use F and R?
                              Including the hybrid styles? I'm planning to replace the TC Kline plates currently on my car and NVH is a concern.
                              Great job and thanks for documenting all of this. I can appreciate the reasoning behind the choices you've made. Looking forward to more reviews of the suspension!
                              2003 Imola Red M3 w/ SMG
                                Ha... more involved question than you might think.
                                I found a line barely barrel springs that eibach makes, which they call their extreme travel line. That allowed me to use a shorter spring (6" IIRC) up front, while still having sufficient travel, which puts the perch above the tire at my desired ride height, allowing me to run bigger tires without compromising offsets (lets me run an ET35 front, which allows me to not have stupid camber to fit 285s). So, my front left is an eibach extreme travel 6" "barrel" spring. Eibach 0600.2530.0350.
                                Front left was tricky because the extreme travel line only comes in 50 lb increments.... but then I realized that GC sells and extreme travel spring (made by eibach, though they don't use that branding-- but visibly the same thing and I confirmed that they were with GC) in 6" 375 lb. Ground control GC150.64.66.
                                Both fronts are either 65mm or 2.5", I forget which (and am pretty sure most spring companies use the same thing here anyway. To fit that on the H&R shock body, I'm using Ohlins spring perches-- same thread pitch, so it's plug and play. Still using the H&R lock ring, because it's free.
                                Rear left is a TCK 700 lb beehive from my old TCK coilovers. TCK TKE 360 700 R.
                                Right rear is a GC linear 650 lb spring... I think 6"? With some of their cones on the top side, to protect the chassis from the spring.
                                Both rears are sitting on the H&R rear ride height adjusters, because they're really nice-- let you adjust the height without taking the spring out, or wheel off, which makes corner balancing way easier.
