2002 Steel Grey 6spd coupe Daily/Restoration project
    I think I got too tired! Thanks
      Shit man, just read this whole thread. Badass job bringing it back to lifel!!
      Had to give a shout out - fab work man.
        Amazing job, dude... The finished product is going to be insane. You going with a ceramic coat or just wax?
          Thanks guys! I tried a turtlewax product that is a polish and seal in 1 (sio2/polymers). As you'll see in the next post or two, the finish came out so perfect from the wetsanding and compound, I truly didn't see a need for a final polish - it was that clear! So I used the TW product more for the sealant than the polish, but it was nice as it killed 2 birds with 1 stone. In the end, the TW product is too watery, doesn't have much longevity, but does look good for a bit. I have another product that's even more ceramic like, probably the closest to a ceramic, called CMX that I'll top with carnauba or beadmaker. I don't want to use real ceramic because it doesn't fit my situation. If I didn't like to try products and didn't diy, and drove more and/or the car wasn't garaged, I'd be inclined to pay for ceramic coating.
            Continued
            Left off last with the door mostly finished, to gauge progress. Now finishing the bottom of the door and more of the QP
            Did the areas around the molding by hand
            All done (Up to the fender bulge)
            Here's the sealant/polish I spoke about
            Time to go back to the wetsanding and finish the QP. Before I did, I washed the car since it had gotten dirty enough in the areas I wasn't working on
            The beads!
            Back in the garage, now I'm working on the end of the QP. The very top, above the tail light, wasn't finished at all. Very rough.
            Done!
            Next will be rest of QP by the gas lid and behind hofmeister kink. And I'm doing the rear bumper as it was also unfinished.
              Quarter panel continued
              I'm very very pleased overall with the paint job itself, but there were a few defects that I'm happy will be gone after the wetsanding I was doing anyway. Immediately behind the hoff kink and some under the top ridge. Not sure if they're solvent pops or air bubbles or contaminants or what.
              Click image for larger version  Name:	wetsand071.JPG Views:	0 Size:	77.8 KB ID:	131640
              Click image for larger version  Name:	wetsand072.JPG Views:	0 Size:	107.7 KB ID:	131641
              Started up the sanding again, right behind the hoff kink
              Click image for larger version  Name:	wetsand073.JPG Views:	0 Size:	70.0 KB ID:	131638
              Click image for larger version  Name:	wetsand074.JPG Views:	0 Size:	78.0 KB ID:	131639
              Click image for larger version  Name:	wetsand075.JPG Views:	0 Size:	82.2 KB ID:	131643
              Click image for larger version  Name:	wetsand076.JPG Views:	0 Size:	75.3 KB ID:	131645
              The rough texture doesn't go up too high on the pillar and above the windows, so I just decided to stop before getting too high up. It's almost a good match to factory in the upper pillar, so I'll get around to it later - not a priority.
              Click image for larger version  Name:	wetsand077.JPG Views:	0 Size:	79.8 KB ID:	131644 Click image for larger version  Name:	wetsand078.JPG Views:	0 Size:	42.6 KB ID:	131642
              Click image for larger version  Name:	wetsand079.JPG Views:	0 Size:	93.8 KB ID:	131648
              Most of the end of the QP was not too textured and I was able to take it easier and finish most of it pretty quickly. It does get bad again, however, right around the gas lid and tail light.
              Click image for larger version  Name:	wetsand080.JPG Views:	0 Size:	68.0 KB ID:	131646
              Click image for larger version  Name:	wetsand081.JPG Views:	0 Size:	90.5 KB ID:	131649 Click image for larger version  Name:	wetsand082.JPG Views:	0 Size:	82.9 KB ID:	131647 Click image for larger version  Name:	wetsand083.JPG Views:	0 Size:	62.4 KB ID:	131650
              Click image for larger version  Name:	wetsand084.JPG Views:	0 Size:	51.2 KB ID:	131651
              Click image for larger version  Name:	wetsand085.JPG Views:	0 Size:	130.3 KB ID:	131653 Click image for larger version  Name:	wetsand086.JPG Views:	0 Size:	79.2 KB ID:	131652
              Click image for larger version  Name:	wetsand087.JPG Views:	0 Size:	62.3 KB ID:	131654
              Alright, all done with the QP except for the little area the runs below the tail lights. I'll show you next how textured that is. The bumper is basically just as bad, so I'll be doing it now too.
              Click image for larger version  Name:	wetsand088.JPG Views:	0 Size:	118.6 KB ID:	131657 Click image for larger version  Name:	wetsand089.JPG Views:	0 Size:	72.2 KB ID:	131655
              Click image for larger version  Name:	wetsand090.JPG Views:	0 Size:	74.5 KB ID:	131656
              Started in on the section below lights. In the section at the very end of the QP, before that break/line, you can see that I've left still a bit of texture. You don't want to sand completely flat (unless your painting ) It should still be smooth to the touch, mind.
              Next post will be finishing the little strip under the taillight/trunk and the bumper.
                Wet sanding rear bumper and rear portion of QP
                Another shot of the back of QP where it meets the trunk. You can quite easily see the disparity in finishes between factory trunk and resprayed QP
                The little strip under the trunk as well
ID:	132480 Click image for larger version
                The respray went all the way to the other side, and they stopped it at the indentation (good spot to do so)
                Started in on the bumper
                Is that a prius?
                Now moving to the back. It looks like the body shop just kept the diffuser on and sprayed it with the bumper. It's hard to work on the bumper, exp near the bottom as it flexes due to being plastic, plus it's just not as secure as higher up or a metal panel.
                The left corner of the bumper already had a scuff on it, so I was careful to sand around that, and let the buffing stage make it look as good as possible.
                Here's another example of how textured the bumper was. Much more noticeable on this side being next to the factory original driver's QP.
                All done! Finally. At this point, I was like 2 weeks into this so I was pretty happy to be done. Buffing/polishing is familiar territory, so the hard part is over!
                You can check your work by viewing the paint at a sharp angle for more reflectivity. Very pleased with this. Buffing next...
                  Man you really saved that paint! Looking great.
                    Thanks!
                    Buffing (removing sanding marks, restoring clarity)
                    Now that the sanding is all done, and I'm going to start buffing with compound (in order to remove deepest sanding marks), I taped off certain surfaces.
                    Before using the D/A machine, I actually used rubbing compound by finger (wrapped with MF towel) in some difficult-to-reach areas, specifically right behind the black pillar gutter/trim. You can see the reflection of the tape. It's difficult to generate enough heat without a forced rotation rotary in funny spots like this, but you can generate plenty of friction by hand, in a small place.
                    Now for buffing. I went back to the medium correcting cream since this end of the QP didn't need so much sanding. Using a medium cutting orange CSS pad.
                    Ostensibly, it looks great
                    But let's look closer, under the fluorescent...
                    Nope, not enough. You can still see some sanding marks
                    Back to the fast correcting compound. I also recently, randomly bought, on clearance, the new Chemical guys hex pad (slightly different than the normal hex pad). I'm not a CG's fan tbh, but I actually like these new hex pads better than my go to Lake Country CSS.
                    All clear! I had to go over the hoff kink area by hand a few times (was lazy and didn't want to get the 3" out which still would have required some manual rubbing anyway (albeit less).
                    I'm really pleased with how this area came out. It was tricky and it was the messiest portion of respray, not just the orange peel, but the extra defects (runs, bubbles, dirt, idk what it all was)
                    Caught the paint (cut, not yet polished even) in natural sunlight. Pretty.
                    I was able to reach all other spots with the 5.5" pad, but I ended up having to bust out the 3", not so much for its size, but more so for the forced rotation. Really cuts down on the buffing time, but you have to be more careful, ofc. I really should get a proper rotary at this point, but oh well. Now, I should only be doing light polishes on both cars. No more heavy cutting unless I decide to take on clients.
                    All done with the QP!
                    Now, it's time for the bumper. Bumpers are plastic, so less rigid, and they're not as rigidly attached as a body panel, so it's much harder to get heat into the panel, thus less cut. I stayed with the fast correcting compound, but moved to the heavy cutting meguiar's MF disc
                    Beautiful!
                    More to come. The rest of the bumper, and the little strip that runs under the taillights.
                      Awesome results!! Give's me a lot more confidence to give wet sanding a go one day 😆.
                        Thanks! It's like anything right, once you try it a bit, you figure it out. Just start light like 2500, 3k and go easy
                          ...the rest of the buffing rear bumper/QP
                          Like I mentioned, the plastic bumper really needs an aggressive machine or at least pads/product to cut through with any decent speed. So I stayed with the 3" MF pad for the top of the bumper, but also the back of the QP. A 5.5" pad wouldn't be precise enough here. You can do small spots with your finger/hand, but that's also time/energy consuming.
                          Even with the small 3", this little strip, below, was tricky. You have to have a sure grip and control so that you don't come off and damage other surfaces. It's also a small area, so easier to burn through since you're concentrating your efforts in such a small area which leads to more heat (cut).
                          The tail lights, though recently polished, still had some defects I thought I could improve on, so I hit them with compound as well. They look great for being original (2006 325ci).
                          Kept using that 5.5" Meguiar's MF cutting disk on the larger area of the bumper. The bumper vibrates a lot which prevents you from heating it up well - the MF pad makes up for that. You do have to be a little careful with the MF pad as it's easier to burn through on high spots. The MF pad, alone, was perfect for most of the bumper (flattest surfaces), but I did have to do a final pass with foam - I'll speak about that again later (see the tow hook cover).
                          Almost there!
                          I'm really pleased with the level of orange peel and overall job I've done, if I may say so. This was a spur of the moment decision (to wetsand), and I'm glad it didn't end with a sad story.
                          Staying on the topic of orange peel, it's not as important that the level of orange peel match factory on a place like the rear bumper, not just because a plastic bumper will never match the body exactly anyway, but because there's no factory panel immediately next to it to compare to.
                          However, the area I was concerned about, was the little bit of QP that wraps around, under the tail light as it butts up to the factory trunk lid, so you've got two surfaces right next to each other. This is a similar issue when it comes to color match of paint.
                          Here's a little video I made, once finished, with the trunk closed, to compare the two surfaces; factory trunk and resprayed QP:
                          Alright, driver side done, now looking at the pass side of the bumper. I put some tape over some pre-existing scuffs. The scuffs were deep enough that the clear was basically gone and I didn't want to remove much more paint (with compound and MF pad).
                          I took the tape off for the final pass with the foam pad. You can barely see any defect! Worked out perfectly.
                          A close up. Even this close up, it looks good. I'll run a damp q-tip through the gap between the bumper and diffuser to clean up left over compound residue.
                          Last last bit before calling it "done."
                          Ok, for real, "Done!"
ID:	133205 Click image for larger version
                          Yes, the bumper is a bit wonky. I'm waiting on a muffler (og scorza) before I drop the stock muffler in order to re-fit the bumper.
                          Did a wash since the rest of the car was dusty/dirty
                          Wow wow wow, I couldn't be happier!
                          The rear end looked too good, I had to cut down and shine up the factory driver QP even better to match it all lol
                          Ok, paintwork is almost all done. Next, I'm going to wetsand the front bumper (also an unfinished respray), and the upper pillar of the passenger QP. After that, I'll cut the rear of the trunk and then do a final polish and seal of the entire car by the end of the year or so. My plan is to try the new(ish) Mother's CMX SiO2/TiO2 polish/sealant, topped with beadmaker after 24 hr cure. Then I'll be done with paint work for a while #sad.
                            Nice man! I’m in San Diego with an 02 stee grey aswell. I’ve been doing a full engine rebuild as well as replacing all the rotting rubber and plastic, and headlight lemses and such. Body work plans to be my next thing. I’m actually buying an OEM csl trunk tomorrow, and plan to have it painted along with a full paint correction in the future
                              Amazing work! It looks gorgeous
                                Thanks, great color!
                                Thank you Ejaz
