Bootloader update MSS54HP & MSS54HP CSL via OBD
    Originally posted by MpowerE36 View Post
    Yes, it allows to write the OEM CSL boot+prog+tune via obd. No need to open the dme.
    What is your issue with the Terra's CSL clone fullbinary ?
    INPA and ISTA both don't communicate with the DME and I just can't read codes. When flashing either the tune of the full binary, it takes many tries to get it to be successful. I have had to reset my flash counter twice just to get it to go through. Granted, there was the first install of the CSL box and then about a year later I had to replace my cluster. It was brand new and programmed through a real ISTA real computer. The DME communicated fine then. Obviously the vehicle wouldn't start if it didn't communicate at all and it does. The issue I have is it takes about an hour or two just to get the flashes to go through just to get the car to start. Never had any DME issues other than this specific one. I wouldn't say it's even a DME issue. I'm not the only one this happens to. I'm not savy with programming so it's just a total mystery to me on why this is happening.
      it will be super cool if it resets the flash counter before flashing.
        Is there a way to revert a BDM flashed original MSS54HP that has been converted to a CSL clone to be reverted back to the original MSS54HP code?
        My original DME had hardware ID of 32300 and after the CSL conversion, now has hardware ID of 32500. I couldn't pass emissions inspection in VA, so would like to convert back to a regular MSS54HP software. However, using my original fullbinary.bin fails with MSS Flasher, as it complains about the hardware ID being different.
        It would be great if I could use your program to go back to my original software.
          Hello I tried to send you a pm but I cant because my account is too new. Could you pm me please?
            Hello. I saw you pmed me but I still cant reply. I sent you an email.
              I used @MpowerE36 software today to flash my MSS54HP Bootloader 32300 to MSS54HP CSL Bootloader 32500. The process was super slick and a straightforward option for anyone who is not planning on adding the H Bridge for the Flap.
              I am still waiting on a few parts to complete the installation of the CSL intake, but I was able to start and move my car after the flash using the stock airbox. My car is an SMG and has the CSL 255 tune so I am sure that helps.
              The next step after getting the missing hardware is getting the Mullet Tune. ​
              2004 M3 Silbergrau (Silver Grey) Convertible SMG Karbonius CSL Airbox Mullet Tune Front 996 Brembos Status Gruppe V2 Headers CPI RTX Sec 1 Kenwood DMX958XR
                MpowerE36 soft now released ?
                  Since February 2023.
                  https://www.youtube.com/channel/UCwN...zf45mXp6PDOCzA
                    How much is the soft ?
