Flashing the MK60 with ZCP software
    Anyone with an actual CSL willing to connect their computer for 20 minutes to pull down a dump of (presumably) an 813.3?
    CSL shares the same part number with the ZCP, so it should have the 817.3
Name:	Screenshot 2026-11-21 at 4.13.10 PM.png
Name:	Screenshot 2026-11-21 at 4.12.53 PM.png
    813.3 came in late model normal M3s (I think). Annoyingly, I was looking through pictures and the MK60 module I took out of my car to replace with the 817.3 was an 813.3...
      Click image for larger version  Name:	Screenshot 2026-11-21 at 4.13.10 PM.png Views:	0 Size:	41.9 KB ID:	616361
      Click image for larger version  Name:	Screenshot 2026-11-21 at 4.12.53 PM.png Views:	0 Size:	164.5 KB ID:	616362
      *should* .. interestingly, if it does then the ZCP technically has the looser oversteer limits due to the taller tires and the way the yaw prediction (and therefore threshold limit) is calculated.
      Well in that case, someone with an 06 M3 then? Man, what a bummer about the swap. Is the car still local?
