Hi,
Ive just fitted my CSL airbox with MAP sensor and IAT as well as the deleting the MAF. I’ve read on what needs to be done to flash my ECU to get the car running however some of the threads are couple of years old so wanted to confirm the best practice for this still. (I’ll Reach out to a tuner at a later stage for fine tuning, but I just wanted to start the car and be able to move it about for now)
I have an 04 SMG car (UK) with an MSS54HP DME and I don’t have the CSL flap installed so I am hoping it keeps things bit simpler.
So using MMS flasher I can take a read of the OEM Bin file for the car and save that.
Then do a flash of Full 211323000401PD31_TERRA.bin from here https://github.com/saildot4k/MSS54-X...4HP%20to%20CSL
Then flash this Partial 211323000401PD11 SMG.bin
I then need to modify tune for the non CSL cams using tuner pro(?)
After the above I believe the car should be good to go, but would I need to do anything with the EWS, or VIN at this stage?
I understand the above will be on the the stock CSL tune modified to run on the non CSL boot loader as the original CSL tune with the CSL boot loader would require a BDM flash, But at this stage I just want to run the car and make sure everything is ok with the install,
Thanks for the help!
Andy
