Originally posted by ppm008
S54 airbox +288/280 schrick on CSL software tune
BMWfanz or other with 288/280 cams, what Ign do you achieved? Compared to more mild cams, on the S54 with 288/280 from a good friend i was quite surprised how low I had to go with ign (with standard knock sensitivity/recovery). Do you encountered the same? AFR is fine, but injector duty.. hm above 7500 it's just static open on E0 fuel (0% ethanol). Of course this needs some slightly bigger injectors.
For idle, zero problems. Not touched it, idle was like nailed. Only in the seat you "feel" the cams a tad.Last edited by S54B32; 06-26-2024, 12:51 PM.…under construction.
Originally posted by S54B32 View PostBMWfanz or other with 288/280 cams, what Ign do you achieved? Compared to more mild cams, on the S54 with 288/280 from a good friend i was quite surprised how low I had to go with ign (with standard knock sensitivity/recovery). Do you encountered the same? AFR is fine, but injector duty.. hm above 7500 it's just static open on E0 fuel (0% ethanol). Of course this needs some slightly bigger injectors.
Hey,
does anyone have an ignition table for a cammed motor they can share? My base map has values that seem to be dialed back a lot and the engine is generating more heat than it should. I also don't want just lower ignition angles per feel, so if theres something out there I just get a feel where a dynoed engine is and use a less agressive value for safety.
I am running 296/288 cams with headwork done and 12.5 compression ratio, so it would help if its from a car with at least 288/280s.
I will also ask the guy that will be dynoing my car tomorrow.2002 E46 M3 TiAg Coupé >> full tracktool conversion @m346gt
What ign you currently running? I had to massive lowering ign@WOT peak rpm to not get knock control kicking in on 288/280. Also lowered a bit later than the knock recovery time. If I remember correct ended somewhere in the range of max 25°.
But if you will go on a dyno you can easy find optimal ign angle, so no need to lower it per feel.…under construction.
Originally posted by S54B32 View PostWhat ign you currently running? I had to massive lowering ign@WOT peak rpm to not get knock control kicking in on 288/280. Also lowered a bit later than the knock recovery time. If I remember correct ended somewhere in the range of max 25°.
Maybe I'm tripping about heat since recently my coolant tank blew 😅
