Hey guys, i've seen on some threads that Virginizing an ECU with MSS Flasher makes it so the Flash counter is unlimited, is that true, if not what does it exactly do, thanks!
MSS Flasher Virginizing ECU
Virginize resets the entire DME, but doing this doesn't change the way the flash counter works. There's also an "Erase FC" button that resets the flash counter without modifying anything else. As long as you reset the flash counter whenever you're approaching the flash limit, you can flash the DME an unlimited number of times.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - SSV1 - HJS - Mullet Tune - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
alright i tried using the Erase FC button but says i need a license, do i really need to pay to get one or is there a way to get one for free? thanks!Originally posted by heinzboehmer View PostVirginize resets the entire DME, but doing this doesn't change the way the flash counter works. There's also an "Erase FC" button that resets the flash counter without modifying anything else. As long as you reset the flash counter whenever you're approaching the flash limit, you can flash the DME an unlimited number of times.
You need to pay.Originally posted by E46 Adam View Post
alright i tried using the Erase FC button but says i need a license, do i really need to pay to get one or is there a way to get one for free? thanks!2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - SSV1 - HJS - Mullet Tune - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
ok and it's unlimited use on any car?Taken from here: http://www.msstuning.com/mssflasher.htmlThe above license will allow an installation on one computer and will be locked to the first three ECUs it will be used with.
Contact us for bulk/other licensing options.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - SSV1 - HJS - Mullet Tune - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
