Any update on locating the 20x24 map? I’ve checked all the maps in tunerpro and have yet to find anything remotely close to a 20x24 sized map.
[Resolved]What Causes CSL Conversion tune to Jerky?
Originally posted by mushitaro View PostThanks to everyone who contributed information to this community.
After running Terra's CSL Tune on my car it jerks below 3500 rpm when running at full throttle. And if this continues, all pistons will misfire.
When I measured the air-fuel ratio, it shows 10.0 up to 3500rpm.
I know this issue has already been discussed, but for those of you who have DIY'd this, how did you tune it?
https://nam3forum.com/forums/forum/s...2025#post42025
I've seen the thread below mention how to deal with this issue.
https://nam3forum.com/forums/forum/s...5420#post75420
However, the heated debate does not seem to have converged.
Can anyone understand and explain the conclusion of this discussion?
What does "simple" mean in the thread below?
https://nam3forum.com/forums/forum/s...5#post42095
This is what I did.
① The fuel injection coefficient of the full throttle map was lowered step by step.
> does not resolve.
② I turned off the catalyst protection control using Martin's tool.
> does not resolve.
My vehicle is January 2004 SMG2(japan).
【Equipment】
・Turner CSL Style Intake Kit
・MSS54HP
・MAP sensor
・Stock M3 cam
・Euro header(Stock)
・Euro Cat(Stock)
・Stock muffler
The cam offset is corrected to stockM3 using Tuner Pro.
Converting the IAT scale to CSL using Martin's tools.
I used testo to confirm that the map sensor is working.
I've attached the BIN with my changes.Last edited by BMWfanz; 08-10-2023, 08:33 PM.
Originally posted by Ryan_R View PostAny update on locating the 20x24 map? I’ve checked all the maps in tunerpro and have yet to find anything remotely close to a 20x24 sized map.
…under construction.
Would you mind editing the original post and confirming what the resolution is? Your thread title says "Resolved" so I assume you found the fix. I've skimmed the thread and don't see the fix - would you mind confirming?
Was this the fix?
"2.After adjusting the KF_TI_N_RF_VL (WOT injection) table, the jerks were almost resolved. It showed an AFR around 12.5 with the following injection factor settings. (I can't show you because I haven't been able to integrate the engine speed and AFR..)"'02 ///M3 Alpine White / Cinnamon 6MT
Originally posted by Bry5on View PostThe linked XDF has them, here's a 3 dimensional plot of the alpha-N map, it shows how much resonance there is between 1500 and 3000 RPM!
https://github.com/Bry5on/MSS54-XDFs...mplete.xdf.txt
With this, I was able to stand at the starting line of the setting.
Was this the fix?
- Likes 3
Thank you very much. Are you the one who created this XDF?
With this, I was able to stand at the starting line of the setting.‘02 332iT / 6 | ‘70 Jaguar XJ6 electric conversion
