RAM_LESEN on MSS54HP with 0401 SW
    Hi Guys,
    I am in the process of defining adx files for ALDLdroid as I have an andoid head unit and the programm is a very convinient life viewer and logger. At the moment I am using the wellknown value block requests (similar to testo serial mode) but would like to get further informations like Zustand_Motor. ba_st, etc.. I would like to try the RAM_LESEN command, but having trouble to make it work on INPA or TOOL32. Has anybody experience in directly reading ram cells on MSS54?
    Thanks in advance,
    Peter
    Sorry I need to be more precise:
    To my limited knowledge the RAM address of ba_st (Status Beschleunigungsanreicherung) in 0401 SW should be​ 0xFF8248 (1 byte).
    If I try to read this address via INPA or TOOL32 the only thing I got is an error
    RAM_LESEN just seems to work without any address respectivly a very low one and I just receive 3 start byte and then FFs up to a total of 128 followed by an end byte:
    Has anyone experienced the same or am I doing something wrong here?
    Cheers,
    Peter
      You have to use as adress:
      0x01FF8248
        Thanks a lot - this helps. But does not work for all RAM adresses, right? Could you shed some light into the logic of accessing higher addresses? e.g. "ZUSTAND_MOTOR" should be on 0xFFE8E2 but I just got an error by RAM_LESEN, 0x01FFE8E2, 1
          use 0x01FF8044 thats the same as ZUSTAND_MOTOR
            Thanks again. Is the pre number related to a register? e.g. a2 is addressed by 0x01xxxxxx, a3 by 0x02xxxxxx?
