Need help doing vanos test with INPA
    though there is not a wall on the inward motion of the spline, there is a hard stop, and that is the slot on the cam sprockets, that is the physical limit, and if the timing was off a bit 59 was as much as it could get.
    Max retarded position is limited by the vanos front covers, and the max advanced position (piston moved rearward) has more margin beyond the operating advanced timing and so this end should have no problem of achieving desired angle = actual angle.
    59 is the Intake actual retarded (limited by vanos cover) and not when the spline bottomed out on the cam sleeve or the cam shaft.
      I think you are just jumping to answer, read what I said. anti-clockwise motion is capped by the caps (pun intended), clockwise motion is limited by the slots in the sprockets. that's it. the cams will get anywhere between those hard points.
        Sorry, but we're talking the timing value during engine running and not during a vanos timing set. The slots in the sprocket are only involved during timing setting and they are useless during dynamic timing change with engine running. As soon as the hub bolted were torqued down, the slots are out of the operation so why they are in the discussion of the advanced angles?
          Thank you so much for the 1 click test solution using Tool32. Was very excited to be able to run a vanos test on my system as a base line before i do a vanos refresh. One thing i'm confused on is why my log file appears to be shorter than some others that have multiple pages. i did a select all or ctrl A in the log area and grabbed the text but my log file i saved in TXT format doesnt have any other sections after:
          apiJob("mss54ds0","STEUERN_AVANOS1_DICHTHEIT",""," ")
          can someone look at mine and let me know if the values are in spec? Or will i need to rerun the test to get more of the log file that i might be missing?
            No problem, glad I could help out.
            Seems OK to me. All jobs were performed that are listed. 1. retard endstop 2. Advance endstop 3. Activation speeds & 4. leakage test for both sides (8 in total)
            Intake is perfect, the position were 0-60°CR (0-60°CR necessary)
            Exhasut same, 0-48°CR (0-45°CR necessary)
            Intake speed very good 195-205ms (BMW says that anything below 500ms is good, I would rather take 250ms)
            Exhasut speed 152-193ms. Exhaust has less degrees to travel (45 vs 60 on intake) I suspect its fast due to this. Numbers looking perfect.
            Both intake and exhaust position are drifted. I am not sure how I would need to understand this. I wouldn't worry about it.
            So no issues and good results.
              thanks so much man.
              just curious why my log appears to be smaller or missing information compared to this other persons in this post
              I'm trying to do a vanos test using INPA but it seems like it's missing that and some other functions. I can connect to the car and get error codes and engine data like rpm, temperature, etc. but it doesn't appear to be fully functional. I've tried two different DCAN cables with the same results. I've reinstalled INPA several
              they seem to have more data? did they run the test differently or did i miss any of the logs somewhere?
                The "dichtheid" / leak test performs OK on these and comes with more data. Still similar jobs being performed
                  Hi - Thank you Tomba for putting this together. I recently rebuilt my Vanos with Beisan seals, etc. and wanted to test it out. Not having access to Autologic, this was great. Question: For the 'drift' test, what is the expected result? I do not see any test results showing other than "AVANOS-1-Einheit vorzeitig weggedriftet".
                  Below are my results: 61 for intake and 47 for exhaust. I also noticed that if ran the test a few more times, the activation speeds seem to improve, but these are the initial results.
                  Results
                  Testdatei : C:\EDIABAS\ECU\MSS54_VANOS_TESTS\MSS54_VANOS_TESTS .TST
                  Start : 03.04.2022 08:32:31.2
                  Nr 1( 1) : 03.04.2022 08:32:31.3
                  apiJob("mss54ds0","STEUERN_EVANOS1_FRUEHANSCHLAG", "","")
                  JOB_STATUS = OKAY
                  EVAN_ISTWERT = 0 00 00 ..
                  EVAN_SOLLWERT = -10 FF FF FF F6 ÿÿÿö
                  EVAN_ISTWERT_EINH = Grad KW
                  EVAN_SOLLWERT_EINH = Grad KW
                  Nr 2( 1) : 03.04.2022 08:32:36.8
                  apiJob("mss54ds0","STEUERN_EVANOS1_SPAETANSCHLAG", "","")
                  JOB_STATUS = OKAY
                  EVAN_ISTWERT = 61 00 3D .=
                  EVAN_SOLLWERT = 75 00 4B .K
                  Nr 3( 1) : 03.04.2022 08:32:42.1
                  apiJob("mss54ds0","STEUERN_EVANOS1_VERSTELLZEIT"," ","")
                  JOB_STATUS = OKAY
                  EVAN_VERSTELLZEIT_FRUEH = 300 01 2C .,
                  EVAN_VERSTELLZEIT_SPAET = 281 01 19 ..
                  EVAN_VERSTELLZEIT_FRUEH_EINH = ms
                  EVAN_VERSTELLZEIT_SPAET_EINH = ms
                  Nr 4( 1) : 03.04.2022 08:32:48.5
                  apiJob("mss54ds0","STEUERN_EVANOS1_DICHTHEIT",""," ")
                  JOB_STATUS = OKAY
                  EVAN_STATUS = EVANOS-1-Einheit vorzeitig weggedriftet
                  Nr 5( 1) : 03.04.2022 08:33:03.0
                  apiJob("mss54ds0","STEUERN_AVANOS1_FRUEHANSCHLAG", "","")
                  JOB_STATUS = OKAY
                  AVAN_ISTWERT = 0 00 00 ..
                  AVAN_SOLLWERT = -10 FF FF FF F6 ÿÿÿö
                  AVAN_ISTWERT_EINH = Grad KW
                  AVAN_SOLLWERT_EINH = Grad KW
                  Nr 6( 1) : 03.04.2022 08:33:08.4
                  apiJob("mss54ds0","STEUERN_AVANOS1_SPAETANSCHLAG", "","")
                  JOB_STATUS = OKAY
                  AVAN_ISTWERT = 47 00 2F ./
                  AVAN_SOLLWERT = 55 00 37 .7
                  Nr 7( 1) : 03.04.2022 08:33:13.8
                  apiJob("mss54ds0","STEUERN_AVANOS1_VERSTELLZEIT"," ","")
                  JOB_STATUS = OKAY
                  AVAN_VERSTELLZEIT_FRUEH = 206 00 CE .Î
                  AVAN_VERSTELLZEIT_SPAET = 231 00 E7 .ç
                  AVAN_VERSTELLZEIT_FRUEH_EINH = ms
                  AVAN_VERSTELLZEIT_SPAET_EINH = ms
                  Nr 8( 1) : 03.04.2022 08:33:20.2
                  JOB_STATUS = OKAY
                  AVAN_STATUS = AVANOS-1-Einheit vorzeitig weggedriftet
                  Stop : 03.04.2022 08:33:35.3
                  Dauer : 64.1 s
                    No or small drift. My suspicion is,
                    - camshaft is set at a position
                    - none of the electric valves are activated for xx seconds
                    - after xx seconds the position at the beginning and end is checked against each other
                    - If too large difference is observed you will see an error
                    But I am not 100% sure.
                      Unzip the attachment,
                      place it in C:\EDIABAS\ECU
                      start Tool32
                      Click the 2nd [OPEN] icon
                      open MSS54_VANOS_Test.tst
                      Press F8 to run all tests
                      A result screen similar to the quoted code text below should appear *tested only with bench set up! Not with a running engine
                      Code:
                      Test file : C:\EDIABAS\ECU\MSS54_VANOS_TESTS.TST
                      Start : 18.06.2020 19:57:00.5
                      Nr 1( 1) : 18.06.2020 19:57:00.6
                      JOB_STATUS = OKAY
                      EVAN_ISTWERT = 60 00 3C .<
                      EVAN_SOLLWERT = 52 00 34 .4
                      Nr 2( 1) : 18.06.2020 19:57:06.0
                      JOB_STATUS = OKAY
                      Nr 3( 1) : 18.06.2020 19:57:11.3
                      JOB_STATUS = OKAY
                      EVAN_VERSTELLZEIT_FRUEH = 0 00 00 ..
                      EVAN_VERSTELLZEIT_SPAET = 0 00 00 ..
                      Nr 4( 1) : 18.06.2020 19:57:17.5
                      JOB_STATUS = OKAY
                      Nr 5( 1) : 18.06.2020 19:57:32.0
                      JOB_STATUS = OKAY
                      AVAN_SOLLWERT = 0 00 00 ..
                      Nr 6( 1) : 18.06.2020 19:57:37.3
                      JOB_STATUS = OKAY
                      Nr 7( 1) : 18.06.2020 19:57:42.5
                      JOB_STATUS = OKAY
                      AVAN_VERSTELLZEIT_FRUEH = 0 00 00 ..
                      AVAN_VERSTELLZEIT_SPAET = 0 00 00 ..
                      Nr 8( 1) : 18.06.2020 19:57:48.9
                      JOB_STATUS = OKAY
                      Stop : 18.06.2020 19:58:03.3
                      Dauer : 62.9 s
                      My results:
                      Start : 01.07.2022 22:30:16.1
                      Nr 1( 1) : 01.07.2022 22:30:16.2
                      JOB_STATUS = OKAY
                      Nr 2( 1) : 01.07.2022 22:30:21.5
                      JOB_STATUS = OKAY
                      Nr 3( 1) : 01.07.2022 22:30:26.8
                      JOB_STATUS = OKAY
                      EVAN_VERSTELLZEIT_FRUEH = 391 01 87 .?
                      EVAN_VERSTELLZEIT_SPAET = 308 01 34 .4
                      Nr 4( 1) : 01.07.2022 22:30:33.1
                      JOB_STATUS = OKAY
                      Nr 5( 1) : 01.07.2022 22:30:47.4
                      JOB_STATUS = OKAY
                      Nr 6( 1) : 01.07.2022 22:30:52.7
                      JOB_STATUS = OKAY
                      AVAN_ISTWERT = 49 00 31 .1
                      Nr 7( 1) : 01.07.2022 22:30:58.0
                      JOB_STATUS = OKAY
                      AVAN_VERSTELLZEIT_FRUEH = 290 01 22 ."
                      AVAN_VERSTELLZEIT_SPAET = 262 01 06 ..
                      Nr 8( 1) : 01.07.2022 22:31:04.3
                      JOB_STATUS = OKAY
                      Stop : 01.07.2022 22:31:19.2
                      Dauer : 63.1 s
                      so, my vanos its ok?
                        Originally posted by GNevarc View Post
                        My results:
                        JOB_STATUS = OKAY
                        JOB_STATUS = OKAY
                        JOB_STATUS = OKAY
                        JOB_STATUS = OKAY
                        JOB_STATUS = OKAY
                        JOB_STATUS = OKAY
                        JOB_STATUS = OKAY
                        JOB_STATUS = OKAY
                        Dauer : 63.1 s
                        Your adjustment range is perfect.
                        0 to 60 for intake and 0 to 48 for exhaust is the spec.
                        Your adjustment times are within BMW spec, but a bit slow in my opinion, mine does intake in 200-230ms and exhaust in 180-200ms, so there is some improvement possible there.
                        Generally we declared under 250ms to be good, iirc.
                        Hope this helps.
                          Hope this helps.
                          Thank you!
                          So, do you know what could be causing this slowness?
                            Thank you!
                            Oil pressure.
                            Solenoids.
                              Oil pressure.
                              Solenoids.
                              Specifically VANOS oil pressure. You may want to get a gauge together and measure. There are some good threads around here on it.
                                I need That!
