Anyone have luck using a Mac to run BMW Scanner? All of my personal devices are Macs (without cd/dvd drives) and it seems like I need any old windows computer with a drive to load the software.
BMW scanner on a Mac?
you should be good, I've found issue with my newer Pro, the older intel Pro still works well outside of needing a new batteryOriginally posted by Hammerfang View PostHow stable is it? My personal MacBook is a late 2018, just worried about how stable it will be
There are FTDI drivers for Windows ARM. New Macbooks should be fine as long as you have the space for the VMware Windows ARM installation (~100GB).Originally posted by YoitsTmac View PostCorrect. I wouldn't recommend doing this on any Mac newer than 2020. That's when Apple went to their own internal silicon. You need an Intel based Mac for the best compatibility to guarantee no issues
Yes, you CAN, but I wouldn't recommend itOriginally posted by Slideways View Post
. You're hoping someone else's homework to translate between architectures is bulletproof while doing operations on a car.
My VM is 15GB with a few snapshots, takes 3GB of RAM and can work on a $150 computer that goes with your other tools, free to get beat up without guilt. Just my two cents. When the silicon matches the intent (IE Intel Mac running windows built for intel X86), there's a lot more implied compatibility since there's less actual firmware required to make it happen. But nothing really wrong using ARM drivers other than they're very new.
The ARM drivers are fine - I've hammered them for a couple of months testing MSS54 DS2 Tool - they're solid.Originally posted by YoitsTmac View Post
My VM is 15GB with a few snapshots, takes 3GB of RAM and can work on a $150 computer that goes with your other tools, free to get beat up without guilt. Just my two cents. When the silicon matches the intent (IE Intel Mac running windows built for intel X86), there's a lot more implied compatibility since there's less actual firmware required to make it happen. But nothing really wrong using ARM drivers other than they're very new.2005 ///M3 SMG Coupe Silbergrau Metallic/CSL bucket seats/CSL airbox/CSL console/6 point RACP brace/Apex ARC-8s
- Likes 2
To be honest I’ve found everything works surprisingly well.Originally posted by YoitsTmac View Post
You're the android in the group chat! lolOriginally posted by Hammerfang View PostAnyone have luck using a Mac to run BMW Scanner? All of my personal devices are Macs (without cd/dvd drives) and it seems like I need any old windows computer with a drive to load the software.
I've seen a MAC being used with INPA without issue. I'm guessing he was using a virtual machine. Of course while he was using it, I mentioned how using a windows-based laptop would be much easier.
Has anyone had issues with USB-C to USB-A adaptors with D-CAN cables? I finally retired my surface from 2019 and my new surface only has USB-C.
Been using USB-C to USB-A with D-CAN cable without issue for a few months.Originally posted by bigjae46 View Post
Just don't breathe near the computer when it is flashing
