I asked claude-code to follow instructions from https://github.com/karter16/CSL_0401...assembly_Notes to set up Ghidra for disassembling my own binary, which I previously dumped with BMWFlash.
Is this a feasible approach? Claude is telling me:
One thing worth your attention: the repo's reference binary (Full 211323000401PD31_TERRA.bin, 1MB) turned out to be two 512KB images concatenated back-to-back — the Master and Slave halves, each with its own CPU32 vector table at offset 0. Your grey_DME_full_v0.2.0.bin is exactly 512KB with the same vector-table shape (SP=0, reset PC=0x200) but a different default-handler address (0x5b0 vs 0x5ce), meaning it's a single Master-or-Slave-equivalent half from a different firmware build — not the combined dump. The load base of 0x0 is correct either way, but I can't tell you from the bytes alone whether it's the Master or Slave side (that matters for which parts of the repo's wiki/identified-functions apply).
Does this make sense? I know I might be able to use the terra binary, but I'd like to:
A. learn
B. disassemble the non-csl binary
So when I dump the full bin with BMWFlash, why is it only 512kb. My dme is mss54hp if that matters.
A. learn
