Is it possible to code the cluster to switch between IAT, Coolant temp and oil temp, instead of average MPG, remaining milage/ tank, outside temp, etc?
Cluster coding with IAT, Water temp and oil temp?
This isn't something you can just code in like you can with comfort locks or comfort windows or whatever. So if it is possible, it would require custom software to be written.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - SSV1 - HJS - Mullet Tune - MK60 Swap - E86 Front Triangulation - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
I am not aware of anyone flashing a custom "tune" (if you will) to a cluster. I imagine there is likely some tamper prevention mechanisms since the cluster displays the odometer value to prevent someone from setting it to whatever they want. You would have a better time getting the ECU to broadcast IAT as the MPG CAN PID.Originally posted by kokgo20 View Post
That’s what I figured
now who can make this happen?
Or just get one of these:
Would be cheaper and easier than trying to modify the cluster computer software.
Can’t sacrifice my air vent completely for anythingOriginally posted by eacmen View Post
currently have built some gauges in my vents that’s are completely functional
1 Photo
Wow. That's cool as f**k.Originally posted by kokgo20 View Post
