SMG CAN-bus is separate from the rest of the bus. If you want to grab the SMG exclusive messages, you'll have to tap into that. 43F is sent from the DME and rebroadcasts some of the SMG data to the general bus.
SMG CAN Bus Decoding
There were a few posts in the old huge MSS54 thread that outlined some of the Arbids available on the SMG specific CANbus and how to enable/disable some of those arbids being broadcast. I am hoping that information was saved somewhere but I cant find it. What I did save is that arbid 720 on the SMG CANbus has the following info:
B0 = Coolant Temp
B1 = Intake temp
B2 = Exhaust Gas Temp
B3 = Oil Temp
B4 = Voltage
B5,B6 = Speed
B7 = Fuel Pump Duty Cycle? - Probably not relevant for euro cars
I think there was a 721, 722 and 723... I think. I don't remember what information was sent on those arbids but I would imagine that it included everything the ECU and SMG needed to tell each other: torque reduction, throttle blip, etc.. I am not sure how else that info would have been communicated and if it wasn't high priority information I am not sure why BMW would have put it on its on dedicated CAN instead of on the other CANbus with the cluster, ABS, etc.
With my DME on the bench and the cansniffer running I get a stream from the following ARBIDs
0x311
Byte: 0 = 00
Byte: 1 = 70
Byte: 2 = Cycles through 0E to FE consantly
Byte: 3 = 7C
Byte: 4 = 00
Byte: 5 = 00
Byte: 6 = 20
Byte: 7 = Cycles through 7x to 8x
0x312
Byte 0: = Cycles through 00 to 0F
Byte 1: = Cycles through 9X to AX
Byte 2: = 00
Byte 3: = 5B
Byte 4: = 00
Byte 5: = 00
Byte 6: = 14
Byte 7: = 05
0x313
Byte 0: = 00
Byte 1: = 00
Byte 2: = 00
Byte 3: = 00
Byte 4: = 00
Byte 5: = FF
Byte 6: = 00
Byte 7: = 36
0x314
Byte 0: = FF
Byte 1: = Cycles through X3
Byte 2: = FF
Byte 3: = 14
Byte 4: = 00
Byte 5: = Cycles through E/FX
Byte 6: = FF
Byte 7: = 37
No SMG unit is connected, just the DME and sniffer on bench.
This is not the most useful format, but I logged PID 0x43f (decimal 1087) using race capture pro. I cycled from Neutral to First, Second, First, Then Neutral. This is the raw data:
Neutral:
First:[1087.0]: 64.0, 6.0, 1.0, 129.0, 123.0, 4.0, 0.0, 254.0,
Second:[1087.0]: 65.0, 1.0, 131.0, 61.0, 123.0, 132.0, 228.0, 254.0,
Seems like the first byte is gear and some kind of state. 64 (0x40) means neutral and and "in gear", during the shift to 1 that first byte changes to 1 then 65 (0x41). So I am thinking that the first half byte is state with &0x40 meaning in gear or not, and the second half of the byte is the gear either being selected or currently selected depending on what the first half of the byte says.[1087.0]: 66.0, 2.0, 133.0, 73.0, 123.0, 132.0, 237.0, 254.0,
Can you shed any light into the structure of 0x43f @olza?
thanks!
Yeah I got tired of doing the decimal to hex conversion in my head. There seems to be alot of data that is constantly changing on that pid even when smg is in idle state.Originally posted by S54B32 View PostYou are right, on B0 is current gear. On B2 is drivelogic. And there is also shift request in the message, aka „blinking“ gear in cluster. To understand better, read a bit about MSB and LSB. Then you will understand real quick the structure.
Any chance smg pump pressure and temps are broadcast on the cluster CAN bus? That would be nice to log.
No, that data is only possible over diagnostic line with request commands (normally comes from Inpa or tool32). The awron display works this way. Therefore it can show data like IAT or exhausttemp, which is never present on CAN bus. You would need a microcontroller that captures this data and stream it back on CAN bus for racedash application etc.…under construction.
That's what I assumed. Thanks for confirming.Originally posted by S54B32 View PostNo, that data is only possible over diagnostic line with request commands (normally comes from Inpa or tool32). The awron display works this way. Therefore it can show data like IAT or exhausttemp, which is never present on CAN bus. You would need a microcontroller that captures this data and stream it back on CAN bus for racedash application etc.
Don’t know if this helps at all but.....
SMG CAN Bus signals:
Engine Speed - transmitted twice to the SMG II control unit. One signal arrives via the SMG CAN, the other arrives via a hard wire from the DME.
Engine Coolant Temp - as needed
Engine Oil Temp - as needed
Intake Air Temp - as needed
PWG - used to calculate engine load
EDR Feedback Pots - provides throttle position information that is used during slip intervention
Wheel Speed - Signal from DSC. Detects vehicle speed and wheel slip in Auto-Mode and during down shifts in all modes to detect drag torque induced wheel slip.
Transverse Acceleration - Signal from DSC. Transmitted in Auto-Mode so up and down shifts are prevented during high speed cornering
Steering Angle - Signal from angle sensor. Monitors cornering and slip info
Cruise Status
Parking Brake - Affects gear engagement and vehicle operation
Door Contacts - Signal via K-Bus and CAN Bus for safety program initiation
Brake Light Switch - Brake pedal status for unlocking shift lock, brake detection, engine starting, downhill detection, clutch engagement while stoppedLast edited by SliM3; 10-14-2020, 05:19 AM.
