Hello,
First off I am aware that there is a thread dedicated to this subject, but I wanted to see if someone has had a similar setup as mine and could answer a couple questions. I have PM's and emailed Martyn, but I was hoping this might be an subject that someone has dealt with in the past. Any advice would be greatly appreciated.
Background: I have a Karbonius Airbox installed on my vehicle with a TTFS rail, and just installed a new GM 1 Bar MAP sensor on the rail. I have double- and triple checked my wiring based off off the ECUWorx Website and everything looks good. I did purchase a terminal lead that I am using as an extension for Pin 18 because I cant get the pin to index properly into the harness based off the thickness of the MAP sensor pigtail wires.
I sent my DME to Kassel to have it flashed to CSL software. I believe they flash a CSL clone software with some various modifications which is where my questions arise. I was given CSL “U.S. Spec” software for my 6MT car.
I know that site says to use non-modified binary for best results. My DME has been modified and I have shift lights, some throttle remapping and the sport button modifications. I do not want to lose these mods, but I also don’t want to mess up the binary tool process if that makes sense. My goal is to change the binary to reflect the physical removal of the SAP I did recently and change the values to scale for the use of a GM 1 Bar sensor. Will I be able to use the tool to change only these values without me screwing up the other work that work that was done by Kassel?
