MSS5x Binary Modification Tool Update
  • x Spades x
    Hey Guys,
    Will the Evap test (emissions) still run, if I "Disable SAP/Cat Heat Sequence" (Disable cold start - checked)?
    Also, does checking "Disable Cat Protection (Disables enrichment)" cause a "gassy"/rich smell? I've been smelling a very rich smell, while the car idle in the garage and wondering if this is the reason.
    Kareem
  • x Spades x
    Thanks!!
  • r4dr
    Can you post the oil temp settings?
    Hello, A question about the instrument cluster. What do the shiftlights monitor? Water, oil engine temperature? Which sensors give the signal for the lamps? someone has information... I think it was described in the old forum, unfortunately I can't read it there :-) Anmerkung 2020-04-14 193917.png Thanks and stays healthy
  • Martyn
    Just set the last slider to 80*C then work backwards in 5* or 10* increments.
  • x Spades x
    That's more or less what my car does now that I changed it to CSL oil temp values. "Full operating temp" doesn't necessarily seem to be the middle hash mark, my gauge usually goes up or down with driving patterns.
  • r4dr
  • x Spades x
    I think you want to adjust it to so the last light goes off till it hits the first dot?
    I wanted to so the last light goes off at full operating oil temp. Does anyone have a pic of the sliders for that?
  • Martyn
    Originally posted by GAM3_OVR View Post
    Hey Martyn,
    I like your binary tool & I tried a few times to find out where to pay for a license/,multiple licenses. Is there a specific link?
    The payment section is within the tool, under 'Action' > 'Generate license request'.
  • GAM3_OVR
    Also thank you for making a perfect fitting baseplate for the Samsonas Shifter & E46 M3 I will mowst likely be buying one soon!
  • GAM3_OVR
    Hey Martyn,
  • 0-60motorsports
    Email Sent Martyn
  • Cubieman
    Hey Martyn, what specific damage can occur when running burble/pop with cats? I've got a Euro exhaust setup so that cats are not on the headers if that makes any difference.
    Does it ruin the catalyst so it can't effectively clean the exhaustb or will melt the catalyst up and ruin your exhaust that way?
  • NZ_M3
    1.6.4
  • Martyn
    What version of the tool are you seeing this on?
  • NZ_M3
    Martyn
    I think you need to look over this software again, I’ve noticed quite a few bugs with it and have been fixing other’s tunes as a result.
    for example, if you do binary modifications via tunerpro or a hex edit tool or apply an already modified file to it and make changes subsequently it does some really weird stuff to the file (makes changes in weird random places and applies incorrect dtc deletions ect).
    also it doesn’t work correctly on 0301 CSL software version.
