Originally posted by Tbonem3
View Post
need advice to fix clear coat defect
If he has good recommendations from people you know, and it sounds like he does, then you've got a steal. Pro body shop would charge you 3 to 5x more.3.91 | CMP Subframe & RTAB Bushings | SMG (Relocated & Rebuilt) | ESS Gen 3 Supercharger | Redish | Beisan | GC Coilovers & ARCAs | Imola Interior | RE Rasp | RE Diablo | Storm Motorwerks Paddles | Will ZCPM3 Shift Knob | Apex ARC-8 19x9, 19x9.5 | Sony XAV-AX5000 | BAVSOUND | CSL & 255 SMG Upgrades | Tiag | Vert w/Hardtop
So, as said above, they only way for a flawless fix is respray. My painter first tried to just respray a tiny area and blend in, but it was a bit obvious. He then sprayed a larger area (from jamb down to moulding up to rubber window seal) and then blended out for perfect color match.
This is the full and expensive way to do it. He said if you simply try to re-clear, you'll always see it and it'll always bother you.
For some, the cheaper and smaller fix might be good enough, but I wanted perfect.
Price is hard to say cause I had other work done. If that was all I needed, it'd probably be like $800-1k.
I'll post a pic at sime point. I may have a "before" close up of the clear coat failure stillDD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
- Likes 2
Sorry, I have pics just have to find time to upload. You can see my car, now, on IG.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
