Hello all, I got into a front end collision on my mostly track car. Slowly transforming into a car that I only take to the racetrack. Long story short, I blew the a/c radiator and all of its compression. If I remove the a/c completely at the front of the car, is there anything I need to be aware of. Do I need this fan anymore? Am I going to trigger a code on the car? Any advice steering me away from doing this also welcome as I’m kinda on the fence about it
A/c removal
None really, just delete the AC stuff. If you remove the condenser then you can remove all of the fans. It will cool better on track. In fact removing the fans has yielded the largest drop in coolant temps on track. Just need to make sure you do a good cool down, maybe take a lap around the paddock afterwards. BUT...the coolant system won't need as much cool down.
Think it's obvious/implied, but removing all fans means no airflow when standing still, so the car will overheat in that situation. Worth taking into account if the car is not 100% a track car just yet.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - Kassel MAP - SSV1 - HJS - PCS Tune - Beisan - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
Remove A/C completely, remove the fan, remove the mechanical clutch fan and instead install an aftermarket puller fan with controller. So no overheating in paddock and better fresh air flow on radiatorGT4 Composites
I added 1/4” steel mesh from Home Depot. Spray painted black to make it more stealthy. It’s protected the parts against large debris, and there are only a handful of bent fins due to small stuff that got thru, as of yesterday.
In case you decide to use a fan, I wired my SPAL fan to the aux fan wiring (both stock fans deleted). Works great both on and off the track.Last edited by SQ13; 03-16-2023, 03:48 PM.
Originally posted by SQ13 View PostI added 1/4” steel mesh from Home Depot. Spray painted black to make it more stealthy. It’s protected the parts against large debris, and there are only a handful of bent fins due to small stuff that got thru, as of yesterday.
Doesn't the aux fan controller vary voltage to control speed? If so, the SPAL fan won't vary speed. Its on/off. You are better off installing a temp switch in the upper radiator hose.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - Kassel MAP - SSV1 - HJS - PCS Tune - Beisan - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
Pretty sure it's a PWM controller. Should work fine with the SPAL.
Originally posted by Jersey_M3 View PostDare I ask what your recommended parts and controllers are for this. Mishimoto looks easy peasy
Doesn't the aux fan controller vary voltage to control speed? If so, the SPAL fan won't vary speed. It’s on/off. You are better off installing a temp switch in the upper radiator hose.
