Originally posted by P3trolPete
Delayed Track Season - Show us your builds!
I know the car is a bit dirty but its been in the garage all winter. This winter saw rod bearings (124K on the originals), Moton 2WR installed and front splitter/brake cooling. For the splitter I used Build journal mounts and quick disconnect bumper setup. Car is going in for corner balance and final alignment in the coming weeks.3 Photos
What material did you use to close up the gaps on the brake duct? Looks good.Originally posted by Sergmann View PostI know the car is a bit dirty but its been in the garage all winter. This winter saw rod bearings (124K on the originals), Moton 2WR installed and front splitter/brake cooling. For the splitter I used Build journal mounts and quick disconnect bumper setup. Car is going in for corner balance and final alignment in the coming weeks.2003.5 Titanium Silver / Black 6M/T (Gone)
I deleted the LCM and all of the wiring. Then realized it kinda needs it so it’s back in. Luckily I only needed to put 6 wires back in for the brake lights. Replaced the brake booster and master cylinder, a $100 check valve fell apart so I’m about $1000 into replacing the OE brake system.
Oh, I painted my wheels techno violet. Also re-did the front aero - Added a front air dam and extended the splitter 2”. Hopefully, just needs a weekend to test and practice not f’ing it up and then try and make a carbon splitter.Last edited by bigjae46; 04-05-2020, 06:55 PM.
. Sad days, but that was the last item to be addressed in the car, at least.
