Originally posted by sc_tr0jan_m3
Track Video Thread
Thankfully not in track. I pulled in cuz I started smelling more brake pad than normal so I backed off and called it a day. It wasn’t until I was swapping wheels around that I found the cracked rotor.Originally posted by eacmen View Post
I assume you cracked the rotor on track? Did you lose brakes completely when that happened?
Consider this a psa to everyone to go check your rotors!!
Sent from my iPhone using Tapatalk2018 Grigio Telesto F80 M3 DCT | :: Bone Stock ::
I had a rear rotor crack on me as well. It was a 9 year old Stoptech disc that had seen over 100 days, most on the front axle and some on the rear.Originally posted by sc_tr0jan_m3 View Post
I’ll admit that I don’t check my rear brakes very closely. I check all of the rotor hat bolts and both sides of the disc on the front.
I only noticed that crack by accident. Brakes felt fine.
VIR Full-2:11.41
**New Catalyst makes posting these videos much easier**2006 ///M3 6MT Coupe Jet Black Track Car
That looks like a fun track!Originally posted by eacmen View Posthttps://youtu.be/qiwMVgvEPqM
Summit Main with NASA. Had to back out of the hot lap as everyone was crawling on the main straight with checkered out (last lap, last day). Approaching my pre-wreck pace. Lot more left in the car.
How do you like your KMP wheel? Do you mind if I ask you what shift module you are running? Love the setup.Originally posted by eacmen View Post
It really is! Only thing its missing is some esses.
Sent from my iPhone using Tapatalk2006 ///M3 6MT Coupe Jet Black Track Car
KMP wheel is awesome, came with the car. Car is an smg so its just the kmp magnetic paddles wired into the factory clockspring.Originally posted by Fresh1179 View Post
Lot's of time on the table still, will write something up for you in the next few week!Originally posted by Bento View Post
