I’m running a wing I got from Amazon.com...bought with Hilton Honors points so it cost me $0.00. It’s probably not optimal but it makes a difference. It really made a difference when I chassis mounted the wing. I’m sure there’s a bunch of drag and it won’t impress anyone.
Really eh? The chassis mount made that much of a difference? I always felt for trunk I hopefully wouldn't need it as much. Like when you push down on the trunk there isn't really any play I can feel. Seems to go straight to the suspension. Front 100% needed that bumper will rip right off lol.
Front lip looks great!
2003.5 Titanium Silver / Black 6M/T (Gone) 2003.5 Carbon Black / Laguna Seca Blue SMG (Dusted) 2004 Carbon Black / Black SMG converted to 6M/T(Current)
Great idea... I'm 50/50 if I'll make the drive down to Houston for the weekend but I'd like to since I haven't done MSR Houston yet. I'd like a closer look at your setup to get some ideas. I love what AJ does, but he does command a high premium!
Do you feel like the trunk mounted wing is solid enough or do you wish you tied it into the chassis?
I got the impression that AJ took the items off his product list that were not the best design aerodynamically. He just recently took off fender louvers after a windtunnel that showed the race louvers were better. That's my assumption for why he doesn't offer the front lip anymore.
He mentioned to me that his apex 8(8inch cord) produces more downforce then the nine lives 9.5 in cord wing (he didn't directly name them but from what he told me I could clearly assume it was that company). And by the look of the airfoil it looks like it will have minimal drag. Just a well designed airfoil.
There are rubber stops which the hinges and bottom of the trunk lid sit on.
But I learned the hard way the front mount points on the trunk lid lift up, they do not push down. Pushing down is one thing...try pulling back on the wing. You’ll get some flex.
Oh interesting. I'll try that when I get the wing mounted, but just pulling up on that side of the trunk with the edge of my fingers did have some play. So would be much work with some leverage the wing would provide. Damn. I really didn't want to make a chassis mount for the rear. lol
Safe to assume the foamcore/carbon is stiff enough that is doesn't need anything to stop the front from bending down?
I could get by without support rods on the front but there would be some flex. Mostly because the mounts. You could add more bracing which adds more weight.
Here are some resources to help you guys get an idea of what works. Aero can be pretty useless or counter productive when done wrong, however, it's not that hard to avoid stupid aero. Perfecting a set up will require some R&D in a tunnel but having an idea of how air flows can put you in the ballpark of the educated. There are some real weird time attack cars out there simple because they didn't research how air flows around cars.
This guy worked for Mercedes F1 team as an aero engineer:
This guy is inactive but his channel was basically the means for him getting his degree through his project. It's very educational: https://youtube.com/user/RotaryRebuilder
