E46 M3 CSL MAP Conversion Kit
    Interested as I’m hopefully planning on installing a csl air box.
    a couple of Qs:
    1. Do you have any available?
    2. Does this come with instructions on how to install?
    3. Assuming I have a CSL converted MSS54hp, If I need to convert the car back to the stock plenum for CA smog proposes, do I have to uninstall this and pull out all the connectors And then put my oem DME back on?
    Please let me know. Thanks!
      Yes.
      Yes.
      You can just unplug the sensor and hide it under the dme cover
      Budget CSL MAP Conversion
        a couple of Qs:
        Answer above!
        pm me when you ready!
        thanks
          pm sent!
            I'm interested!
            Confirming this MAP conversion kit will work with the following kit from IND:
            https://ind-distribution.com/product...ant=4280014100 9092
            (Will this MAP conversion kit work with an OE BMW M3 CSL IAT Sensor + Alpha N MAF-to-IAT Conversion Harness??)...or will this MAP conversion kit nullify the IAT sensor/conversion. ​
              If these are still being made, I’d like to order one. Thanks!
                Also interested if still available
                  Bump for a good seller
