DIY: Z3 Non-M gauge cluster to Z3M S54 Conversion
    JMH083,
    Welcome! If I understand what you’re saying, that should work. You need to read the dump from both the internal EEPROM and the coding plug EEPROM from your original cluster. Then write both of those onto your new one. As long as you have successful reads and writes, you’ll have a clone of your original cluster, with mileage and vin transferred.
    Thanks,
    Joel
      Hi Joel
      Thanks for your prompt reply, really appreciate.
      So I will try, there are two option to copy dump from coding plug and internal eeprom : remove eeprom by hot air gun or to use special plug to get contact with pin
        I have a 2001 50k KM cluster I can share the bin dumps from, as well as a brand new uncoded cluster that is virgin to share bin files from. The uncoded cluster isnt of much use though.
        is there not a way to code the nonM canbus cluster via winkfp to flash z3m firmware into it?
          Unfortunately, as far as I’m aware, Z3 clusters don’t use a flashable firmware. These clusters are coded instead. So WINKFP doesn’t have any functionality for them. I have tried coding it with NCS expert, but so far I haven’t found a way to make the necessary changes with NCS expert. If you feel like sending it to me, I’d be interested in seeing the dump from the uncoded cluster.
          Thanks,
          Joel
            Thanks,
            Joel
            Hey Joel yea it seems thats correct, I have since looked into it for the firmware and it wasn't included in the winkfp software package. I have briefly tried .bin flashing an 09.99 canbus cluster with the 50k km cluster dumps I have, and it gave an eeprom error code. I think the internal eeprom didn't take. I always desolder, using TL866 II, straight forward. I haven't tried re-doing it or investigating as no time in that moment, but I will do and try to verify what went wrong.
            Once I get 10 posts here, I'll be able to message you. I might just upload to a fileshare and paste it here though.
              Hey everyone, the forum has failed to notify me of a few DM's via email recently. Since I don't sign in here very often, I've missed a few messages recently. I think I'm caught up on DM's at the moment. If you've sent me a DM recently, and I haven't responded, please send me another message. Life has been busy recently, so I may have totally forgotten to respond to someone. I check my social media a lot more regularly, so if you're having trouble contacting me here, try one of my social media accounts. My instagram is: @joelbanzhaf. I still commonly build these clusters for people, and am also happy to assist any of you attempting it yourself.
              Thanks,
              Joel
