DIY: Z3 Non-M gauge cluster to Z3M S54 Conversion
    JMH083,
    Welcome! If I understand what you’re saying, that should work. You need to read the dump from both the internal EEPROM and the coding plug EEPROM from your original cluster. Then write both of those onto your new one. As long as you have successful reads and writes, you’ll have a clone of your original cluster, with mileage and vin transferred.
    Thanks,
    Joel
      Hi Joel
      Thanks for your prompt reply, really appreciate.
      So I will try, there are two option to copy dump from coding plug and internal eeprom : remove eeprom by hot air gun or to use special plug to get contact with pin
        I have a 2001 50k KM cluster I can share the bin dumps from, as well as a brand new uncoded cluster that is virgin to share bin files from. The uncoded cluster isnt of much use though.
        is there not a way to code the nonM canbus cluster via winkfp to flash z3m firmware into it?
          Unfortunately, as far as I’m aware, Z3 clusters don’t use a flashable firmware. These clusters are coded instead. So WINKFP doesn’t have any functionality for them. I have tried coding it with NCS expert, but so far I haven’t found a way to make the necessary changes with NCS expert. If you feel like sending it to me, I’d be interested in seeing the dump from the uncoded cluster.
          Thanks,
          Joel
            Thanks,
            Joel
            Hey Joel yea it seems thats correct, I have since looked into it for the firmware and it wasn't included in the winkfp software package. I have briefly tried .bin flashing an 09.99 canbus cluster with the 50k km cluster dumps I have, and it gave an eeprom error code. I think the internal eeprom didn't take. I always desolder, using TL866 II, straight forward. I haven't tried re-doing it or investigating as no time in that moment, but I will do and try to verify what went wrong.
            Once I get 10 posts here, I'll be able to message you. I might just upload to a fileshare and paste it here though.
              Hey everyone, the forum has failed to notify me of a few DM's via email recently. Since I don't sign in here very often, I've missed a few messages recently. I think I'm caught up on DM's at the moment. If you've sent me a DM recently, and I haven't responded, please send me another message. Life has been busy recently, so I may have totally forgotten to respond to someone. I check my social media a lot more regularly, so if you're having trouble contacting me here, try one of my social media accounts. My instagram is: @joelbanzhaf. I still commonly build these clusters for people, and am also happy to assist any of you attempting it yourself.
              Thanks,
              Joel
                Learning
                  Hello everyone,
                  I’m trying to convert the odometer display from miles to kilometers on a US-spec M3 cluster (HW7.1, SW24).
                  I’m fairly new to EEPROM work, but I’ve managed to read the cluster and successfully extract both EEPROM dumps. I’ve been working with a hex editor for about a week now, comparing my dumps against several EU cluster dumps.
                  I also attempted to change the unit using NCS Expert, but it didn’t seem to have any effect on the cluster.
                  So far, I’ve noticed that if I copy the first 64 byte pairs from an EU dump into my own, the cluster will display mileage in kilometers and the tamper dot disappears. However, it still retains and displays the original mileage in miles, with the kilometer value shown separately in the corner.
                  Any further modifications I’ve tried result in an “EEP-2” error on the cluster, so I’ve backed off from changing anything else blindly.
                  One concern I have is that the EU dumps I’m comparing against are not from M3 clusters. I’m worried that differences in configuration (such as speedometer scaling and RPM scaling) may be outside of the correct range for my cluster if I try to apply those values directly.
                  At this point, I’m not fully sure how the mileage, unit conversion, and checksum/data structure are tied together in this EEPROM. I’m looking for guidance on how to properly approach this conversion, or what I may be missing in terms of the correct bytes/structure that need to be modified.
                  If anyone has experience with this cluster or can point me in the right direction (even just concepts or what to look for in the dump), I’d really appreciate the help.
                  Thanks in advance.
                    Hi JackCob,
                    Send me (or post) your modified dump that’s displaying in KM. Also, the NCS Expert method should work. You’re possibly just using a profile that doesn’t support writing. But regardless, it won’t actually convert your mileage to KM. The EEPROMs store the mileage as basically a unit-less number. So when you change the units, the number does not change to match the new units. I’ll send you new dumps with your mileage updated to the correct value in KM.
                    Thanks,
                    Joel
                      Hi Joel,
                      Thanks, that makes a lot of sense regarding the mileage being stored as a unit-less value. I had originally thought switching units would recalculate the mileage to km, but your explanation clears that up.
                      I’ll have another go with NCS Expert — I might’ve been using the wrong profile or missed something there, so I’ll report back once I’ve tried again.
                      I’ll also send over the modified dump that’s displaying KM (it’s only the internal EEPROM), but it’ll probably be in a couple of days as I don’t have immediate access to my workshop.
                        Quick update — I’ve managed to resolve this.
                        The miles/km setting is controlled in the internal EEPROM manufacturer data block, not through NCS Expert coding. I identified the relevant bytes and checksum logic and was able to toggle the display successfully.
                        I’ve documented the full process in a separate thread here:https://nam3forum.com/forums/forum/e36-1992-1999/e36-coding-tuning/351103-changing-odometer-display-miles-↔-km-on-bmw-e36-vdo-cluster-hw-7-1-sw-24
                        Thanks everyone for the input — it helped point me in the right direction.
                          I just rebuilt my cluster for my S54-swapped Z3. Here are the major additions:
                          - I used the EEPROM coding bin file JBanzhaf kindly sent me, and the chip seemed to flash on the first try using the EEPROM writer tool he recommended. I did not alter the coding plug, so the mileage tamper light was on, but I was able to sync the mileage with the trip reset button, navigating through the menus.
                          - I used gauge faces from Speedometer Conversion Solutions in Utah; they have black gauge faces that give more of a 'sleeper' 90s vibe.
                          - I installed a gauge.s from Sorek. This involved cutting the gauge faces with a razor blade, finishing the cut with sandpaper, and using some dark metallic paint to match the housing walls to the other window. This process was tedious but well worth it, the Gauge.s looks very OEM+, and I doubt 99.9% of the population could tell it is not OEM. I wired the button for the Gauge.s to a modified fog light switch, where I removed the latch, so it is now a momentary pushbutton. This lets me monitor/log all of the data on the K-Line, so for an S54, the important ones for me are Oil temp, Coolant temp, and IAT.
                          Huge shoutout to JBanzhaf, he made this possible for me.
                            Hello everyone, I have a BMW E36 with an S54 swap.
                            I would like to install a BMW Z3 M instrument cluster, because I want to use the CAN bus functionality in order to integrate an MK60 DSC module and also get the A/C system working properly through the MSS54 DME.
                            I think I will be able to find a Z3 M cluster soon, but I'm struggling to find a wiring diagram or pinout for it.
                            Could anyone tell me which pins on the Z3 M cluster are CAN High and CAN Low, or point me to the correct wiring diagrams?
                            My goal is to use the cluster as the CAN gateway between the MSS54, MK60 DSC and A/C system.
                            Any help would be greatly appreciated.
                            Thank you!
                              Hi Maverick, here is the pinout for the Z3 CAN cluster. Let me know if you need anything else.
                              Thanks,
                              Joel
                                Hello,
                                This is my first time posting on this forum. I came across your thread about the E36 and would like to ask for your help. Please excuse my limited English.
                                I am currently having an issue with an EEP_1 error on the instrument cluster of a BMW Z3. After reading your thread, I learned that the external EEPROM may be the cause, so I read the data from both the internal EEPROM (93C56) and the external EEPROM (93C46).
                                Would it be possible for you to check and correct the data and send the repaired files back to me?
                                If you are able to help, I can send both EEPROM files via private message.
                                Thank you very much for your time and consideration.
