MSS6x Flasher - Now released!
  • terra
    Originally posted by SYT_Shadow View Post
    Shouldn't we be able to bypass tune read protections on the ECUs?
    What if I have a tune with read protection but want to remove or add cold start for example? There should be a way to do that
    Unfortunately with the way the flash routines are setup on the MSS6x, it's not really doable without wiping out the tune altogether. If you can do a BDM backup then it'd be possible to defeat the bypass in there and reflash, but unless you own a very early M3, your DME will be BDM locked.
  • tdott
    I think it's done for tuners IP protection and to force you to go back to the tuner to make any changes.
  • SYT_Shadow
  • tdott
    In order to find out all I have to do is try to read the tune? 'Read tune'?
    Yes, try it and let us know how it goes. I was planning to order a new cable and try it out, but haven't yet.
  • SYT_Shadow
    Originally posted by derbo View Post
    My tunes were encrypted and it was unable to read them. I would imagine you would have the same issue?
  • derbo
    I have so many questions...
    I bought the special bimmergeeks cable following the instructions in the OP. I probably already have 6 cables that would work but it's best not to brick the ECUs.
    I have two E9X M3s, a 2013 6MT E92 and a 2011 DCT E90. Both have different aftermarket tunes on them. Originally the 2013 was the track car and has a catless tune, but now the situation is reversed. I would like to basically swap tunes.
    To do this, I 'read tune' from car 1, save the file, then go to car 2 and 'flash tune'?
  • SYT_Shadow
  • MSSAddict
    Hi guys I have an MSS65, I read the left side today, but the right side I can't read it, my BDM is a KTAG, anyone know why please?
  • Paddy
    does anyone have the pinout for reading and writing on the table?
    mss65
  • Kaikane40
    Sweet!
  • Paddy
    have now ordered a cable with EdiabasLib firmware. thank you
  • Martyn
    You can try and get the SK depending on whether its responding, I personally woudn't try writing with that cable though.
  • Paddy
    I need more information. What steps did you take, what cable do you have, are you using the latest version?
    I had to reflash the ECU in WinKFP.
    the ecu has water damage. can i get the ews. copy?
    I got cables from doitAuto. never had any problems with
  • Edouard
    THX Terra work great
  • tdott
    Originally posted by jumper View Post
    A big compliment to Terra
    For the less inclined, what is this showing?
    Is it a modified file being flashed with WinKFP?
    Was this after using a backup from MSSFlasher?
