MSS6x Flasher - Now released!
  • MSSAddict
    The RSA BYPASS went well for my MSS65 on the bench,
    Now i can read the RAM and lSN Number
  • sjsuM5
    You could make a full backup, flash to stock with WinKFP, and then flash your backup back.
    l’m a little nervous about using WinKFP, I still have a back-up of my stock tune, can I just re-flash that?
  • terra
    Originally posted by sjsuM5 View Post
    I have tune on my E60 M5 that failed CA smog inspection.
    With this software can I...
    1. Backup my DME with tune
    2. Flash DME back to stock (so I can pass smog inspection)
    3. Re-flash DME with tune
  • sjsuM5
  • Lambda1
    You got PN .
    Mates I hope you understand I dont share this file with all... is taken from mine ecu ... so also VIN, SCK... inside and I dont want share to all.
    Thanks for understanding.
  • Martyn
    I've given up on hopes for an EWS/CAS delete
  • Lambda1
    I could but it will destroy your dreams about ews delete... isnt inside. Wiesmann solve by pushing ews4.3 system in the cars...
  • Martyn
    Could you send it to me too please? Many thanks!
  • Lambda1
    Would be curious to see that Wiesmann backup. And if you happen to have any motorsport dumps, would love to get my hands on those.
    Hi, no problem.
    Ive sent you processor l+r via KTag BDM via message.
    Regards and keep the job going on.
    For MSS60 the tools works awesome so far.
  • terra
  • Lambda1
    So will this work with a MSV70?
    I dont think so.
    Does anyone has any OE Dumps from an MSS65 Manual or SMG Cars?
    Here attached. I also got Wiesmann MF5 backup and other mss60, mss65 backups.
    For me tool works fine with MSS60 atm at bench, for MSS65 it doesn't show VIN => cant safe file :/. Need to check if its DME problem.
  • ZiMMie
  • jmcgikk
  • FritzP
    Originally posted by nymike View Post
    HI,
    CAN SOMEONE POST BENCH FLASHING PINOUT FOR MSS60 ?
    I have used this pinout for bench-connection with good success: see attached picture.
    You will need to set your cable to D-CAN.
  • nymike
    HI,
