Oh yeah, failed to specify that. Can confirm, both cables had the latency timer set to 1ms.
MSS6x Flasher - Now released!
Just for fun I went back to 241E program with autologic. It seems like I don't need a RSA bypass despite going back to stock?
When I try RSA bypass, it says the full read after autologic was not stock.
I could go straight into flashing my tune and car starts up okay. Is the RSA bypass somewhat permanent?
Did the autologic do a full program write or did it just rewrite the tune? Full program write should disable the RSA bypass. Tune write will not.Originally posted by omhl View PostJust for fun I went back to 241E program with autologic. It seems like I don't need a RSA bypass despite going back to stock?
ahh i see.
seems like Winkfp (update) does the same thing. So if I was already on 241E seems like most programs out there like winkfp and autologic etc will only write the tune portion of it. Just a PSA if anybody is wondering.
Now I'm wondering how to force a full program reset. Maybe I have to downgrade and then upgrade.
Martin was instructing omhl, your problem is something else.Originally posted by CaptainPunPants View PostIt failed with that option checked AND unchecked. When it succeeded with the old KCAN cable, it was unchecked.
I'm starting to suspect the new cable might be spotty. But I'm also hesitant to try an unnecessary flash with the old cable to test that hypothesis.
Playing around with K-line mode on my bench, it does seem like there might be an issue somewhere there, though tracking it down is proving to be tough. I think part of the issue might be that K-line mode seems to be straight up faster than D-CAN mode for this purpose. Will see if I can tweak some settings to get it to work a bit better.
Edit: So using the FTDI driver to access the cable instead of the virtual COM port seems to work better. Does suggest it's a speed / timing issue.
Minor Update (Now Version 1.0.0.3)
Changes:- The application will now default to using the D2XX Driver instead of the Virtual COM Port. This seems to be more stable for K-line mode communications, should not cause any regressions for other cars
- In this mode, the settings you have in device manager (COM port, latency, etc) shouldn't matter.
- If you wish to go back to the Virtual COM Mode, Edit the "MSS6x Flasher.exe.config" so that "Port" is set to the COM port you desire (default is now "FTDI0")
- Note: This will probably not work properly if you have multiple FTDI devices connected at the same time. If you have multiple FTDI devices, you can try to select the specific device you want using the instructions under "FTDI D2XX Properties" here
- Eliminated the slow RSA bypass. Just seemed to create confusion.
- Made some changes so that if one of the stages during a flash process fails, the program doesn't try to perform the subsequent steps.
First thank`s for this wonderful app !
Question: Would it be also possible to use a ICOM instead of Bimmergeeks Interaface ?
and for Beginners another Question:
I have an original 2007 M5, not tuned.
So the first i made, was, to press button "Read full Flash" ,with standard-cable D-Can. The complete reading process took approx 60 minutes. Now there are two files saved, one "full" and one "tune".
After that, i successfuly loaded the "full-file" to Binary Modification Tool".
So that`s it, i`v done so far.
Now please give me help/correction:
1. First to be able to save ISN, I have to flash DME with "Flash RSA Bypass" (only with edibasLib - Cable)
2. Saving ISN
so far it is clear, but then...
3. After step 2, i`ll have to press button "Read full Flash" again ? The bypassed full-file will now be saved on pc. ?
4. Now i have to load this bypassed full-file to Binary Modification Tool, change values and load it back to MSS6x-Flasher. ?
5. So what is to do ? do i have to press Button "flash Tune" or "flash Program" ? I don`t know the difference between these functions. With Binary Modification Tool, it`s not possible to load the tune-file, only full.
sorry for asking, but i`m not familiar with tuning a DME , so please can anybody make step by step guide ?Last edited by Lucky; 05-04-2020, 03:09 AM.
To be able to save the ISN, yes, you have to flash the RSA bypass.
Now honestly, it's not as critical to back that up on an M5 for a few reasons.
1) A "virgin" DME can be synced with the CAS and get the ISN back that way
2) Even if your DME did brick, it's not BDM locked, so the ISN can always be recovered that way.
Extracting the ISN from the DME is more useful if you need to replace the CAS module for whatever reason.
Anyway -
You don't necessarily have to read the full flash again unless you want that backup to have the ISN within that full flash file. You could just copy the ISN to the correct location with a hex editor.
If you're just making modifications to your tune (maps, error codes, etc), you only need to flash tune, and that will not require you do an RSA delete at all. If you're getting more into the code modification side of things, then you'll be messing with flash program, and that does require the RSA delete.
does that mean, i have only to load the original full-file (stock-file) in Binary Modification Tool, then for example i set checkmark to "Vmax Limit Removal" - and then it`s enough to flash only the tune ? no RSA-bypass requiered for this action ?Originally posted by terra View Post
