MSS60 XDF Mappings
    It will be very similar to MSD80/81 in which there will also be a Vorsteuerungkorrektur which is a "fuel scalar" map which will make alternative fuels much easier to tune. Here is an MSS60 damos I have no use for. It will only open on WinOLS 4 and higher.
    Rename .txt into .rar to open.
      Hello I've merge some info in a text file so I put them here.
      241E guide
      Tune location:
      Tune 0x00000-0x0FFFF Full 0x070000-0x07FFFF
      Tune 0x10000-0x1FFFF Full 0x2F0000-0x2FFFFF
      V-max map:
      0xB090-0xB137
      Full bin offset +7000
      5x 8x2map, [08 00] separator
      Stock:
      00 00 00 01 00 02 00 03 00 04 00 05 00 06 00 07
      11 60 11 60 11 60 11 60 11 60 11 60 11 60 11 60
      last:
      0F C0 0F C0 0F C0 0F C0 0F C0 0F C0 0F C0 0F C0
      Full speed:
      1F 40 1F 40 1F 40 1F 40 1F 40 1F 40 1F 40 1F 40
      all
      Rev limiter:
      0x6052-0x6071
      Rev limit = Hex value in decimals
      Pedal:
      Full bin offset +2F0000
      Pedal position 0x1ACB2-0x1ACC5
      Limp map 0x1ACC6-0x1ACD9
      DTCs
      Each DTC has a 26 byte row
      To delete a DTC, null 3rd to 10th and the 13 byte
      The DTC code is on the 2 first byte, all code id coulb be find on tool32
      Cats efficiency:
      Bank 1 0x170C-0x1725
      Row:
      27 89 04 20 00 00 00 00 00 00 01 01 01 01 01 01 02 00 58 00 58 01 58 1E 5C 55
      Bank 2 0x1726-0x173F
      Row:
      27 8A 04 30 00 00 00 00 00 00 01 01 01 01 01 01 02 00 58 00 58 01 58 1F 5C 55
      Secondary air pump (SAP):
      0x1AF8-0x1B02
      Row:
      27 AF 00 00 00 00 00 00 14 11 01 01 01 01 01 01 02 00 58 02 58 03 5C D6 5C DB
      and
      27 82 .. ..
      I've also done a very quick XDF file with some maps I found, someones not enough really identified (they include a "?" in their title. Change the extension of the txt to xdf.
      Do someone has a full winols version to explore the ols file existing? It could be interesting to port the maps to an xdf file i think.
        Originally posted by afv View Post
        Rev limiter:
        0x6052-0x6071
        Here are some other rpm limiters I found :
        Click image for larger version  Name:	limiters.PNG Views:	0 Size:	35.2 KB ID:	71142​
        Martyn I noticed that your bin modification tool only lists the "hot" oil rpm limiters, maybe you could add the cold one too !
          Hi everyone, I'm fairly new to the ECU scoping game, but I'm interested in helping, as I've never done this before and would love to learn. I have a buddy with an E92 M3 MSS60. I used to have one and always hated never being able to check out the tune myself. I've recently been helping another friend with his MS54HP E46 M3, and discovered the .zip also contained Function frames for the MSS60 at least partially translated, with the remainder still in German. This got me interested into learning more about that ECU. I'm sure you guys have found this already, considering you've mentioned the functions in this thread. If not I can link it as well. What do I need to get started in finding tables in the address spaces within the DME? Will I need the car? I can do some googling, but so far WinOLS and a dump from the DME? I hope to tune his M3 and also be able to learn more about understanding address locations and how to find them and create an XDF and bin for tuning.
          Link to MSS60 Function frame partially translated: https://file.io/H2gr0LizxMNZ
          Thanks guys,
          Nick
            2 new values identified :
            K_GANG_I_HA_HS - Final drive Manual - 0x13632
            K_GANG_I_HA_DKG - Final drive DCT - 0x13634
            x/1024
            Precision 3
              Guys, any tips on decompiling my bin with IDA ? I find myself stuck know, I've a bunch of maps that I see in the bin but can't identify further. If I could correlate block diagrams from the funktionrahmen to some decompiled subroutine I guess I could identify them ?
              terra Martyn ?
                terra Martyn ?
                Are you already familiar with IDA and want to know specifics like memory map and whatnot? Or is this a more general question?
                  Well I have a version of IDA installed and already did some tinkering with embedded systems ( jtag, gdb, crosscompilation, creating board support packages ).
                  I need some help guiding me through because I am pretty certain I am completly oblivious on a lot of the power of IDA.
                  Would a full read of one side ( inj or ign ) would be a good starting point ? Will I miss some boot code ?
                    Hey guys, I think I've found KF_TI_SOLL_MIN ( minimum injection time ) and KF_TI_SOLL_UB_OFFS ( injector dead times )
                    Comments are welcome
                      K_KH_N_MAX ( RPM threshold for cat preheat deactivation ) -> set this to a low value to deactivate cold start.
                        @16AEE
                        KL_MD_RF_MAX_ROH ( Max relative Filling / RPM )
                        20x1
                        X : RPM x 1 , precision 0
                        relative filling, x/10000 , precision 3
                          hi guys
                          thank you for sharing i'm slowly interested in the s65 do you know where the exhaust vanos tables are, and exhaust heating, i found the intake / and heating vanos tables but the exhaust tables i have a doubt, thank you
                          for 240e soft
                            here damos file
                            if any membre have map pack please send here
                              Click image for larger version  Name:	cold_start_nmax.PNG Views:	287 Size:	8.6 KB ID:	77441
                              Is this the stock cold start max rpm value in the screenshot or lowered value to deactivate code start?
