Caliper bleed screw broken off...
    Originally posted by Bebop View Post
    SteelGreyM Where are you located? If you're somewhat close by or want to ship the caliper, assuming you didn't completely ravage it with a drill bit, I could try to extract the bleeder for you. I have the tooling and experience.
    That would be sweet. Unfortunately I did ravage it with a drill bit. I can send some pictures later after work and let you be the judge
      No problem. DMs open.
          So how screwed am I?
            Seems shitty. You have a welder?
            because welding a nut onto that is gonna be the best way to get it out.
              Agreed.
              Good clean up, a couple of zaps to build up a little nub and un freeze the rust bond and it'll pop out.
              That said a reman caliper is cheap:
              34212282195rKT - Brake Caliper - Rebuilt - Rear Left - E46 M3 | Turner Motorsport
                Agreed.
                Its a ZCP/CSL caliper. $600 new
                  I’m telling you, take to a machine shop that uses a process called EDM. Look up shops near you that do this process. Have had to get this done in past on a expensive/rare caliper. Look it up, calipers with hard metal housings are good candidates for this.
                    Originally posted by old///MFanatic View Post
                    I'm telling you, take to a machine shop that uses a process called EDM. Look up shops near you that do this process. Have had to get this done in past on a expensive/rare caliper. Look it up, calipers with hard metal housings are good candidates for this.
                    The caliper is just an expensive paperweight now…
                    Got a brand new one for $430 so not terrible
                    They are my local dealer and have the cheapest parts I’ve ever seen. Cheaper than online or anywhere on almost every part. Glad I found em
                      There is video on YT on this process
                      they used a reverse drill bit to extract the broken bleeder
                      i will see if i can find it
                        soak with ATF then just tapping on the Impact Drive with a flat bit as I posted previously. Make sure to set the ID to turn CCW.
                          Found it
                          Sorry they are called left hand drill bits set carbide tips
                          Watch the video below
