Caliper bleed screw broken off...
    Originally posted by Bebop View Post
    SteelGreyM Where are you located? If you're somewhat close by or want to ship the caliper, assuming you didn't completely ravage it with a drill bit, I could try to extract the bleeder for you. I have the tooling and experience.
    That would be sweet. Unfortunately I did ravage it with a drill bit. I can send some pictures later after work and let you be the judge
      No problem. DMs open.
          So how screwed am I?
            Seems shitty. You have a welder?
            because welding a nut onto that is gonna be the best way to get it out.
              Agreed.
              Good clean up, a couple of zaps to build up a little nub and un freeze the rust bond and it'll pop out.
              That said a reman caliper is cheap:
              34212282195rKT - Brake Caliper - Rebuilt - Rear Left - E46 M3 | Turner Motorsport
                Agreed.
                Its a ZCP/CSL caliper. $600 new
