Originally posted by Obioban
View Post
PCS Tuning (Paul Claude) or HTE Performance (Hassan) for Karbonius CSL airbox tune?
Derek Polmax is actually highly regarded in the industry so you're good through him but yes, the fakes are sadly a very real thing.Originally posted by Obioban View PostNot saying anything positive or negative about that particular vendor (I know nothing about them), but there are a TON of very convincing Chinese fake Bosch injectors out there, than can lean your engine to failure when they give up. I would be suspicious of any good deals, and not want to buy this product from anyone who isn't an established company with a name to lose.
https://www.bigbanginjection.com/why...SAAEgK48_D_BwE2003 E46 M3 TiAg/Cinnamon 6MT
2005 E46 330i ZHP Imola/Sand
Instagram:@thegenius46m
We’re you able to use ProTuner or another software to verify the injector duty cycles being maxed out? I’d like to try and see where mine are with the stock injectors and recent tune. If so, what tables should we reference?Originally posted by thegenius46m View PostJust a little update here...
Ive been working with Hassan over the past month and it appears there was some miscommunication between us one way or the other months back. Either way doesn't matter because he went out of the way to make this right and gave me a lot of insight that other guys aren't going to tell you which says a lot about his character and expertise here.
Big one is the injectors... that was my primary problem here. My fuel trims were maxed out all across the board, not just up top so he really had to dial back the tune originally to keep everything safe due to hardware limitations. I thought it was only in the higher revs so blamed a tuning issue. Clearly not solely the case here. I upgraded to EV14 Bosch 550cc injectors and it is night and day.
Hassan was almost completely able to fix the drivability issue I had before because he had to detune for the lack of fueling from the stock injectors.
With porting, schrick 280/272 cams, upgraded and lighter single groove valves, and the 550cc injectors the car is still making power on the dyno at 8600rpm without drop off and it feels considerably faster from 3k+. With stock injector the power dropped off at 8200rpm and the car drove like crap imho. Bucking and hesitation is virtually gone and drivability is significantly improved. The engine feels smoother and pulls significantly harder all the way from 3k up.
My head is flowing so much air that he had to add a significant amount of fuel to get the AFRs in check and the result is exactly what I was looking for, a stock like driving experience with significantly more power.
Long story short, if you do cams or anything more than basic bolt ons, just do yourself a favor and upgrade to a higher cc injector. Stock is a genuine waste of time and the tuning will suffer greatly.2005 BMW M3 ZCP Black/Black - HTE Tuning | Kassel CSL DME | 280/272 Schrick Cams+P54 Followers | Dinan TBs | Bosch 550cc | Radium Fuel System | Karbonious CSL Airbox+OE Snorkel | SS V1 Stepped+Catted Sec 1+Resonated Twin Pipe+Race | 3.91, 3 stage clutch | FCM 336/600 | Vorshlag Camber Plates, RSM | Rogue ASP | AKG FCABs, SFBs | TMS Front Sway, Camber Arms, Monoball RTABs, Pullies | Mason Race Strut + X-Brace | AS 30% SSK | SPAL | Redish Plates | VAC Exhaust Hub | WPC Rod Bearings
Stock injector duty cycle is like 85-90% at stock 280 whp I believe. So imagine what it's at if you're making 20-25% more power...Originally posted by duracellttu View Post
We’re you able to use ProTuner or another software to verify the injector duty cycles being maxed out? I’d like to try and see where mine are with the stock injectors and recent tune. If so, what tables should we reference?Instagram: @logicalconclusion
- Likes 2
Wow, how is this not more widely known? When reading through all the different cam and CSL airbox upgrade threads I never saw one mention of upgrading fuel injectors. Wondering if that’s why I’m flat lining up top.Originally posted by EthanolTurbo View Post
This is my build progression. Green is current setup.
Could be. Flatline up top could also be vanos related.Originally posted by duracellttu View Post
There was a good amount of discussion about this on the old forum, no so much on this one. Some good info in this thread though: https://nam3forum.com/forums/forum/m...fuel-compliantOriginally posted by duracellttu View Post
Thanks! Can the stock fuel pump handle the 550cc injector demands?Originally posted by heinzboehmer View Post
There was a good amount of discussion about this on the old forum, no so much on this one. Some good info in this thread though: https://nam3forum.com/forums/forum/m...fuel-compliant2005 BMW M3 ZCP Black/Black - HTE Tuning | Kassel CSL DME | 280/272 Schrick Cams+P54 Followers | Dinan TBs | Bosch 550cc | Radium Fuel System | Karbonious CSL Airbox+OE Snorkel | SS V1 Stepped+Catted Sec 1+Resonated Twin Pipe+Race | 3.91, 3 stage clutch | FCM 336/600 | Vorshlag Camber Plates, RSM | Rogue ASP | AKG FCABs, SFBs | TMS Front Sway, Camber Arms, Monoball RTABs, Pullies | Mason Race Strut + X-Brace | AS 30% SSK | SPAL | Redish Plates | VAC Exhaust Hub | WPC Rod Bearings
I'm honestly not sure.Originally posted by duracellttu View Post
Do the typical supercharger kits come with an upgraded fuel pump? If not, then it's probably fine2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - SSV1 - HJS - Mullet Tune - MK60 Swap - E86 Front Triangulation - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
Yes, I have definitely read up on issues from Chinese Bosch injectors and the dangers that they present.Originally posted by Obioban View PostNot saying anything positive or negative about that particular vendor (I know nothing about them), but there are a TON of very convincing Chinese fake Bosch injectors out there, than can lean your engine to failure when they give up. I would be suspicious of any good deals, and not want to buy this product from anyone who isn't an established company with a name to lose.
My question is, if the seller is stating that the injectors are manufactured in Germany could there still be any issues? How could one tell if the injectors are made in Germany or China?
So you don't think there would be any issues buying those injectors through the Polmax site for a setup similar to your setup?Originally posted by thegenius46m View Post
Think it would depend on where polmax is buying from. Maybe you can ask him, and say that you've read about how good the fakes are.Originally posted by bmw m3 s50 View Post
My question is, if the seller is stating that the injectors are manufactured in Germany could there still be any issues? How could one tell if the injectors are made in Germany or China?DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
I'll assume you didn't see the verification site I listed at the top of this very page...Originally posted by bmw m3 s50 View Post
I did but assume that the site won't help until you have the actual injectors to run the numbers on the verification site. Would be nice to know before even making the purchase.Originally posted by Jimbo's M View Post
Sure it would. That said, gotta start somewhere. If you're worried about the purchase, contact them and verify that they're returnable, especially if https://protect.bosch.com/ says they're fake. For all I know, they use the site themselves.Originally posted by bmw m3 s50 View Post
