RACP Failure After Plates
    Yes yes, we all know plates isn't the end all be all for RACP failure yaddah yaddah yaddah. I am by no means saying I was surprised, I just wanted to share an experience and with visual evidence - especially since M3F is no longer here and there were a lot of resources there regarding this matter.
    Anyway, my car has TMS reinforcement plates installed and previously had stock subframe/differential bushings. I've always kept an eye on the rear despite the fact for exactly this reason. My car is an '04 so it has the updated spot welds as well. And she is also tracked and driven (I think) like a proper M car. Here are the cracks which I initially found.
    Click image for larger version  Name:	IMG_0027.jpg Views:	46 Size:	173.3 KB ID:	10543
    Click image for larger version  Name:	IMG_5527.jpg Views:	45 Size:	250.1 KB ID:	10544
    Click image for larger version  Name:	IMG_9090.jpg Views:	46 Size:	219.2 KB ID:	10546
    Once I took it to the shop and they took off the sound deadening and dropped the subframe they found additional cracks. The RACP was tearing itself apart!
    Click image for larger version  Name:	IMG_1421.JPG Views:	45 Size:	45.1 KB ID:	10547 Click image for larger version  Name:	IMG_1422.JPG Views:	45 Size:	85.7 KB ID:	10548 Click image for larger version  Name:	IMG_1420.JPG Views:	46 Size:	65.5 KB ID:	10549 Click image for larger version  Name:	IMG_1419.JPG Views:	45 Size:	102.4 KB ID:	10550
    As you can see, once the plates are installed the mounting points are no longer the weak spot and the stress continues to flex the RACP. I knew it would have additional cracks but I didn't think it was going to be this bad. The cracks were stitched up and I went with the Turner Delrin/Aluminum subframe bushings and AKG poly diff bushings. All in all I'm very impressed how well the car feels now. Solid, direct, and with a teeny weeny little diff whine - which I kinda like haha. The whine has actually attenuated since I first drove it to where I barely hear it even with windows up and stereo off.
    Click image for larger version  Name:	IMG_2895.jpg Views:	46 Size:	79.2 KB ID:	10551 Click image for larger version  Name:	IMG_7627.jpg Views:	45 Size:	90.7 KB ID:	10552 Click image for larger version  Name:	IMG_8966.jpg Views:	45 Size:	99.5 KB ID:	10553 Click image for larger version  Name:	IMG_2076.jpg Views:	46 Size:	96.3 KB ID:	10554
    Now that she's back on the road I'm thinking of preventative measures to prevent this from happening again. I have an xbrace which I bought and haven't had the time to install. But from my understanding, it only addresses the rear two mounting points. So if I install it, I have to somehow address the front two points. I'm sure the RACP will hold on until I figure out a solution, especially with the solid subframe bushings. I think that made the biggest difference in terms of reducing flex in the rear.
    Click image for larger version  Name:	CACADC83-D544-4B79-B56A-3692394C75F2.JPG Views:	45 Size:	239.1 KB ID:	10555
    How many miles did the car have when the plates were welded on, and how many does it have now? Did it have the same stock subframe bushings this whole time?
      ~90k miles between plates and now. Currently sitting at 190k. And no, the subframe bushings were replaced the last time with stock bushings.
        Oh wow I assumed the interval between plate install and now was much shorter. Honestly looks better that I though for having had plates and no topside reinforcement for 90k miles.
          Climate where car was for those 90k?
            thats a lot of cracks and after a 190k, the metal is pretty much fatigued. you may squeeze a little more life out of that RACP but im sure the cracks will come back. with that kinda, damage, its best to go with a whole new panel IMO
            2007 Imola Red Z4M Coupe
              Plates are not a fix.
                Southern California for its entire life. Dry heat, no ocean spray.
                  Did you read my post?
                    I wouldn't say a whole new panel. But definitely Vincebar/CMP type reinforcement is needed as it relieves the carrier panel from most of the stress from the subframe. I'd say its important to weld any existing cracks before installing one of the said components as well.
                      is it possible to inspect for crack just from the trunk? or do you have to remove the whole rear subframe to get a better look?
                      90k and driven the way it should have sounds pretty impressive for just plates.
                        If you have damage that can be seen from inside the trunk then there will be a lot more damage underneath. You need to remove the subframe to find all cracks, since most of the time there will be some around the subframe mounting points and these will be covered up by the bushings.
                          +1
                            Literally the first sentence...
                            I think we need forum guideline to not post a response unless op's post is read in full and all the other posts that are part of the discussion also. Sometimes people read the title, think they know the question and come in guns blazing with a response. Unless you are just having fun and post nonsense (like I do sometimes).
                            Youtube DIYs and more
                              Have you talked to Cayn from CMP? He is very knowledgeable and accessible and easy to catch in a chat on FB. He might be interested to chat about your case. He also has interesting materials published https://cmpautoengineering.com/pages/technical
