Originally posted by Cubieman
Another Vanos Oil Line Leak Or Something Else?
It comes with both orings and filter.Originally posted by Cubieman View PostI would buy a new regulator and o-ring if it doesn't already come with one. The pressure gauge/fitting I bought of ebay from the UK took months to come. Contact Raj at Beisan, he sent me a gauge to help troubleshoot a vanos issue I had and told me he had planned on selling them soon, so maybe you could get one comming in days not months.
Good luck.2003.5 MT JB/B - CSL SCHRICK SUPERSPRINT EISENMANN JRZ SWIFT MILLWAY APR ENDLESS BBS/SSR DREXLER KMP SACHS RECARO AR SLON MKRS GSP DMG KARBONIUS CP AUTOSOLUTIONS KOYO
That black band used to be an o-ring when new. It's only flattened because it's old and heat cycled. Definite preference for the new part.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - SSV1 - HJS - Mullet Tune - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
Wow, thanks. Its perfectly flattened without any bulges like might be present on a deformed part. I'll be sure to use the new one.Originally posted by heinzboehmer View PostThat black band used to be an o-ring when new. It's only flattened because it's old and heat cycled. Definite preference for the new part.
I'm installing a new vanos plate with the viton orings. Is there any reason to take off the solenoid for additional deep cleaning? Beisan DIY suggests doing so but not sure if that's overkill or worth the extra effort.
You will have your solenoid block out regardless to change the plate or the orings in current plate so I would take the time to clean it via the magnet method, might as well.Originally posted by SMGM3 View Post
You do need some pretty strong magnets though, if you have an old HDD from a desktop PC at home you don't mind losing open it up and use the neodymium magnets found inside.2004 Silbergrau Metallic 6MT
I like your thinking. Gotta be an old HDD around here for the task.Originally posted by Cubieman View Post
