Originally posted by Obioban
Coolant temperature gauge issue
Tried that method. With car off it was a little under 1/4th mark. Once started it jumped to 1/4 at 29 degrees. Rose to 65 in 3 minutes. After about 5 minutes it was up to 81. This was all in 79 ambient outside temperature. I went on a drive and it never went above 86 on a couple of hard pulls. It's not the heat of the day in Texas today though, it's usually 90+ degrees outside here.Garage:
2002 BMW M3: Slicktop jetblack/cinnamon. SMG to 6-speed. Arc-8's. Koni yellows/Dinan springs. Macht elbow. Megan headers. Stock section 1+AR20. SCZA section 3.
2001 BMW 740i
Coolant=29C = 84F and ambient = 79F. Wonder if 5 degrees diff is due to sensors or engine still warm even resting overnight.Originally posted by Circa Surviven View PostOnce started it jumped to 1/4 at 29 degrees. Rose to 65 in 3 minutes. After about 5 minutes it was up to 81. This was all in 79 ambient outside temperature.
The pics show the gauge is bad.
Yea sorry, I should have put 79f to not make it confusing. Is the gauge controlled by the temp sensor under the manifold or the lower radiator hose? I've read that a bad temp sensor would cause fueling issues because the computer will think the temperature is off. Does the car have an actual overheating message/light, or an ecu code that would pop up?Originally posted by sapote View Post
Garage:
2001 BMW 740i
Get an infrared thermometer and confirm the radiator is consistent temps across the entire width. It may be clogged and time for a replacement OEM one. Did you bleed the cooling system properly to remove all the air? S54 is self bleeding but if you had a massive amount of air it may still be there.2003 E46 M3 TiAg/Cinnamon 6MT
2005 E46 330i ZHP Imola/Sand
Instagram:@thegenius46m
The hidden displayed temp value and the gauge both use the sensing data from the sensor on the hard pipe under the intake, rear of the pump. From the pic showing the displayed 85F-ish while the gauge was over the middle. This means the sensor is OK but the gauge is out of calibration.Originally posted by Circa Surviven View PostIs the gauge controlled by the temp sensor under the manifold or the lower radiator hose? I've read that a bad temp sensor would cause fueling issues because the computer will think the temperature is off. Does the car have an actual overheating message/light, or an ecu code that would pop up?
That is Celsius.Originally posted by sapote View Post
The answer to this is all in the first post.
STOP CHASING GHOST!
FIX THE DAMN CLUSTER!Last edited by ZiMMie; 07-14-2021, 11:50 PM.
Thank you! I wasn't able to find a DIY on that sensor under the manifold. Usually with a DIY people will list symptoms of why they are in there replacing it.Originally posted by sapote View Post
The hidden displayed temp value and the gauge both use the sensing data from the sensor on the hard pipe under the intake, rear of the pump. From the pic showing the displayed 85F-ish while the gauge was over the middle. This means the sensor is OK but the gauge is out of calibration.Garage:
2001 BMW 740i
I had mine repaired by Circuit Board Medics and would recommend them. https://circuitboardmedics.com/1999-...luster-repair/
Or buy a used one on eBay.Originally posted by BMWE46M3 View PostI had mine repaired by Circuit Board Medics and would recommend them. https://circuitboardmedics.com/1999-...luster-repair/
Just FYI OP, swapping in a new (used) cluster is a bit more than involved than just physically doing so. Your mileage will be off and the cluster will have the tamper dot until you sync the VIN and mileage.Originally posted by sapote View Post
Here's some resources on how to do that in case you wish to go the DIY route:
https://www.bimmerforums.com/forum/s...VIN-and-coding
https://forums.autolanka.com/topic/1...cement-coding/
Edit: wait, I just read through the post again (and looked at the pics) and the needle isn't all the way to left with the car completely off? You should really disassemble your cluster and make sure that the needle is physically aligned correctly before spending any money on anything else. The second link I posted is a good reference for how to disassemble and reassemble the cluster.Last edited by heinzboehmer; 07-15-2021, 12:29 PM.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - SSV1 - HJS - Mullet Tune - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
For some reasons I thought the temp gauge can be separated from the whole cluster; I own too many vintage cars.Originally posted by heinzboehmer View Post
Yea with the car completely off it stays around the 1/4 marker or a little below. It just started happening one day.Originally posted by heinzboehmer View Post
The cluster hasn't been touched. I guess this would be a good time to get some of the engine warming up lights replaced since some are burnt out.Originally posted by Obioban View Postyeah. A needle that's pushed too far onto it's peg can bind. Or maybe it just wasn't oriented on the peg correctly...
Was the cluster apart before this issue occured?Garage:
2001 BMW 740i
