Originally posted by Obioban
Coolant temperature gauge issue
Garage:
2002 BMW M3: Slicktop jetblack/cinnamon. SMG to 6-speed. Arc-8's. Koni yellows/Dinan springs. Macht elbow. Megan headers. Stock section 1+AR20. SCZA section 3.
1998 Mercedes E300 Turbodiesel: Pizza bag warmer.
Originally posted by Circa Surviven View PostOnce started it jumped to 1/4 at 29 degrees. Rose to 65 in 3 minutes. After about 5 minutes it was up to 81. This was all in 79 ambient outside temperature.
The pics show the gauge is bad.
Coolant=29C = 84F and ambient = 79F. Wonder if 5 degrees diff is due to sensors or engine still warm even resting overnight.
Garage:
Get an infrared thermometer and confirm the radiator is consistent temps across the entire width. It may be clogged and time for a replacement OEM one. Did you bleed the cooling system properly to remove all the air? S54 is self bleeding but if you had a massive amount of air it may still be there.2003 E46 M3 TiAg/Cinnamon 6MT
2005 E46 330i ZHP Imola/Sand
Instagram:@thegenius46m
Originally posted by Circa Surviven View PostIs the gauge controlled by the temp sensor under the manifold or the lower radiator hose? I've read that a bad temp sensor would cause fueling issues because the computer will think the temperature is off. Does the car have an actual overheating message/light, or an ecu code that would pop up?
The hidden displayed temp value and the gauge both use the sensing data from the sensor on the hard pipe under the intake, rear of the pump. From the pic showing the displayed 85F-ish while the gauge was over the middle. This means the sensor is OK but the gauge is out of calibration.
The answer to this is all in the first post.
STOP CHASING GHOST!
FIX THE DAMN CLUSTER!Last edited by ZiMMie; 07-14-2021, 11:50 PM.
The hidden displayed temp value and the gauge both use the sensing data from the sensor on the hard pipe under the intake, rear of the pump. From the pic showing the displayed 85F-ish while the gauge was over the middle. This means the sensor is OK but the gauge is out of calibration.Garage:
I had mine repaired by Circuit Board Medics and would recommend them. https://circuitboardmedics.com/1999-...luster-repair/
Originally posted by BMWE46M3 View PostI had mine repaired by Circuit Board Medics and would recommend them. https://circuitboardmedics.com/1999-...luster-repair/
Or buy a used one on eBay.
Here's some resources on how to do that in case you wish to go the DIY route:
https://www.bimmerforums.com/forum/s...VIN-and-coding
https://forums.autolanka.com/topic/1...cement-coding/
Edit: wait, I just read through the post again (and looked at the pics) and the needle isn't all the way to left with the car completely off? You should really disassemble your cluster and make sure that the needle is physically aligned correctly before spending any money on anything else. The second link I posted is a good reference for how to disassemble and reassemble the cluster.Last edited by heinzboehmer; 07-15-2021, 12:29 PM.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - Kassel MAP - SSV1 - HJS - PCS Tune - Beisan - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
Just FYI OP, swapping in a new (used) cluster is a bit more than involved than just physically doing so. Your mileage will be off and the cluster will have the tamper dot until you sync the VIN and mileage.
Originally posted by Obioban View Postyeah. A needle that's pushed too far onto it's peg can bind. Or maybe it just wasn't oriented on the peg correctly...
Was the cluster apart before this issue occured?Garage:
