Mini DIY: How to reuse stock throttle body clamps
    Just found this video showing how to remove and reinstall the stock throttle body clamps.
    I've resued mine tens of times and never had any issues. I've found that once you get the hang of them, they're just as easy to take on and off as worm clamps. But the stock ones will never interfere with your throttle linkage.
    You can use a tool like the one used in the video, but I just use regular needle nose pliers.
    Additionally, I've found that clocking the clamps in the following fashion will give the best access for the next time they need to come off. No need to remove the fuel or air rails if they're clocked like this. It does help to disconnect the idle air valve connector and move it out of the way, though.
    Cylinders 1 and 2:
    Click image for larger version  Name:	20210711_164518~2.jpg Views:	206 Size:	151.8 KB ID:	118098
    Cylinders 3 and 4:
    Click image for larger version  Name:	20210711_164515~2.jpg Views:	172 Size:	155.5 KB ID:	118099
    Cylinders 5 and 6:
    Click image for larger version  Name:	20210711_164526~2.jpg Views:	175 Size:	151.0 KB ID:	118100
    Note: Cylinder 6 clamp is on backwards compared to the others. I've found it makes it easier to get on and off.
    Hopefully this helps someone!
    I've always wondered why people go to those ugly worm style hose clamps when these can be re-used so easily. On the other side all you need is CV boot type pliers to crimp down the boots to your new CSL intake and there's really not going to be a reason to ever have to mess with them again for quite some time if ever.
    Keep it OEM people!
      Totally agree. These clamps are very easy on/off and reusable.
        thank you for the diy. it'll come in handy if i have to swap the tps under the intake
          These clamps are the biggest PITA until you figure out how to use them. Now they are amazing. haha
          2003.5 Titanium Silver / Black 6M/T (Gone)
