Had to visit the smog shop yesterday prior to registration. After sitting in line over an hour ( 101 degrees outside ) it's my turn. The short version is that the car failed, and the instrument cluster showed a yellow DSC light and a yellow "brake" light. To clarify, the word "brake" was yellow. Turns out that the test was run with engine off - can't explain that, it was running when I exited the car. Ran the test again, engine running, those instrument lights still showing, and it failed again. The car failed to communicate both times, so it showed as fail. Charged me $17.00 and recorded no fee charged. Next, I demanded my cash back, and got it, also got a widget to install in OBDII port for the drive home. Not sure what the widget's for, but was told to leave it there pending my return to the shop. At home, I shut off the engine and re-started it. No lights showing on the dash, so I measured battery voltage. Engine off = 12.55 v, engine on, 14.00v. Should I be concerned about those lights showing then going out? I'm not checking for faults until passing smog.
Sorry about droning on, and appreciate any thoughts.
