Hey y’all, I hit a nice pothole the other day and blew the rubber though the original driver side rear shock mount. No big deal, could have been worse. I replaced the shock mount with an identical Lemforder mount… and 10 miles later the rubber pops out of the mount again. At this point I have to ask, is something else causing this or are these OE units really that poorly designed and I’ve just had a very unlikely coincidence. Any similar experiences before tackling it again?
Rear shock mount troubles
The first time was from an impact. That’s not uncommon to bust it.
The second was a premature failure. That is very often from not installing the bottom washer.
Other than that make sure you got the M3 RSM and not the weaker basic RSM.6MT SLICKTOP - OE CSL Wheels - OE CSL Brakes - CSL Rack - CSL Trunk - CSL Diffuser - AA Tune - AA Pulleys- AS 40% SSK - 4.10 Motorsport Diff - Bilstein PSS9s - H&R Swaybars - Euro Bumper - Gruppe M CF Intake - Supersprint - M Track Mode
old///MFanatic thanks for the insight! I can’t remember now if I missed the bottom washer or not (entirely possible)- I replaced them with the Rogue mounts. All seems good now.
The factory washer cups over the factory bump stop - more surface area for the bump stop to contact. If the washer is smaller than the diameter/shape of the bump stop, the bump stop can fail prematurely.Originally posted by chris719 View PostDo you need the top and bottom cupped washers for the RE RSM? Rogue has a video where they use the stock cupped washer above the bump stop AND their washer. They don't show the top-side BMW cupped washer but I have seen forum posts suggesting you need it.
Makes perfect sense to me, although probably a PITA to get a socket on the nuts with that in place. Any thought on the top nut? Ben doesn't show the stock washer in this old video.Originally posted by Slideways View Post
That's right, I forgot about the clearance issue. That's probably why BMW used studs on the RSM and had the fasteners on the top, plus the hardware won't corrode if it is in the trunk.Originally posted by chris719 View Post
https://www.youtube.com/watch?v=HAyx9m60Dx0
Well RE does include a top reinforcement ring, which BMW doesn’t use standard. So they welded the studs to that, so could be utilized facing down. Allowing an easier removal of the rear shocks after without need to delve deep into the trunk liner.Originally posted by Slideways View PostThat's right, I forgot about the clearance issue. That's probably why BMW used studs on the RSM and had the fasteners on the top, plus the hardware won't corrode if it is in the trunk.6MT SLICKTOP - OE CSL Wheels - OE CSL Brakes - CSL Rack - CSL Trunk - CSL Diffuser - AA Tune - AA Pulleys- AS 40% SSK - 4.10 Motorsport Diff - Bilstein PSS9s - H&R Swaybars - Euro Bumper - Gruppe M CF Intake - Supersprint - M Track Mode
