  • cobra
    Thanks for the positive feedback! I'm glad everyone made it back alive
    This shouldn't have happened to begin with -- please install the update linked below.
    To close the loop on this, the log file showed the ignition going off, but the BlueBus was writing the radio UI.
    Upon closer inspection of the messages, the ignition off message was seen by the BlueBus and the phone was disconnected, but the radio did NOT tell the CD Changer (BlueBus in this case) to stop playing. The effect here is that without the stop playing message, the BlueBus didn't update its internal state to know that it should no longer be writing the display.
    I fixed this by adding code to update the internal state when the ignition off message was seen, only if the "stop playback" message had not already been processed.
    I believe this to be a bug with the specific software revision of the radio as I have never encountered this in the past.
    Nevertheless, it is fixed in this software revision:
    Update instructions are here: https://github.com/tedsalmon/BlueBus...rmware-Upgrade
    Thanks!
    -Ted
    Thanks for the update. Would any new unit purchased today forward have the latest firmware?
    Originally posted by duperdog View Post
    Just installed the latest firmware and disconnected the trickle charger as I've been having the same parasitic drain issues, but didn't have the time to chase it down. Really hoping this resolves it as I've been reluctant to go anywhere and park it for more than a few minutes.
    Thanks.
    Let us know how it works out.
  • duperdog
    Thanks.
  • t3ddftw
    Originally posted by R1pilot View Post
    Just popping in to say that I bought an e83 X3 in Seattle to drive back to Florida with the family and took my Bluebus with me after reading it would work in that car. After connecting it, the sound was awful, I contacted Ted and right away he knew what the problem was and how to fix it. He went back and forth with me in emails until I was able to get it up and going.
    Driving through Montana/Idaho/Wyo without radio would have certainly ended up in my not making it back with my three kids ... someone would have died, lol.
    I cant say enough good things about Ted and his awesome customer service.
    Thanks Ted!!
    Do you recall the fuse numbers? I have an excuse to take the m3 out of the garage tonight and figured I can try this real quick.
    Edit: pulled fuses 7 and 41, cycled key, reinstalled fuses. Blubus now working as intended.
    Originally posted by strummr View Post
    Was anything actionable gleaned here? I'm having a similar issue, where the battery becomes fully discharged - sometimes in a day, other times in a few days to a week or so with the M3 not being used. (I have a fairly fresh battery, and had the alternator replaced with an OEM Valeo unit, late last year.) I should also note, I have tested the battery and it holds a charge without issue, and there has been times after an extended drive, it has been fully discharged by the next morning. (when driving, the Bluebus unit is always on)
    I've had the car without battery issues for the 3 years of ownership, and the battery becoming fully discharged, started right after installing my Bluebus unit in spring - and it does seem a condition where the unit may not be turning off fully at times. (not saying it is the reason, but just noting the coincidence in re: timing)
    Originally posted by Rekpoint View Post
    unfortunately no progress. I tried logging it and I did it wrong. Should be going back this weekend but I need more info from ted since Im not that great with technology. Going to email him back now.
    Thanks!
    -Ted
  • Rekpoint
  • strummr
    Will go home this weekend and do this for him. Will report back via email.
  • Chas3n
    Once in while, the nav or radio fuse needs to be pulled to reset the system.
  • R1pilot
    Thanks Ted!!
  • Slideways
    I believe I disconnected and then reconnected it, but no communication was present. I'll be pulling the car back out this week so I'll try that again. Any other tips?
  • Chas3n
  • t3ddftw
    Has anyone's unit just stopped functioning? Power light shows, but there seems to be no communication with the headunit.
    This isn’t outside the realm of possibility. Did you
    cycle power to the unit? What software version are you on?
    Sometimes it can get stuck in endless loops (well, I don’t know of any in current builds, but it has happened).
    I’ve been meaning to implement the hardware watchdog timer.
    -Ted
  • Chas3n
  • Rekpoint
    Do you think he could follow this process (https://github.com/tedsalmon/BlueBus...athering-a-Log) and just leave the laptop in the trunk for 15 minutes or so? The log will help me narrow down the chatty cathy.
    -Ted
  • t3ddftw
    He left the car sitting all night, blue light was still on this morning. Although his phone doesn’t see it on Bluetooth.
    -Ted
  • Rekpoint
    1. Open the trunk
    2. Ensure the LED (green or blue) on the BlueBus is visible.
    3. Remove the key from the ignition
    4. Close all the doors minus the trunk
    5. Walk away for 5 minutes.
    When you return, the LED on the BlueBus should be out. If it isn't, then I need to investigate the cause (the only one I am aware of is the center console phone keeping the car awake when you replace the factory TCU with a BlueBus).
    -Ted
  • Rekpoint
    1. Open the trunk
    -Ted
    Sent him this, I will report back either tonight or tomorrow.
